Technical Bais front tires
Discussion in 'Traditional Hot Rods' started by stegman, Mar 23, 2014.
  1. A Rodder
    A Rodder
    I agree. The original comment said AFTER he did the balancing he would check the rim. At that point it wouldn't matter, right?
    I would check the rim first as well.
    I I was just saying it would be a moot point to check the rim at that stage.
  2. wheeltramp brian
    wheeltramp brian
    dyna beads should cure it .ive put them in every customer car with biasplys and no problems.
  3. Ole don
    Ole don
    Look up who sells tires for construction trucks. The 15/22.5's Super Single fronts we used all had to be ground to make them round.
  4. the-rodster
    the-rodster
    We run old steel wheels that are often out of round.
    We run new Coker bias plies that again, are often out of round.
    Sure, shaviing will cure the problem.
    But before I did that I would have them road force balanced.
    They take into account the wheel and tire, and mount the tire
    on the rim where, if possible, the two should cancel each other out.
    Rich
