Technical Ball honing a block
Discussion in 'The Hokey Ass Message Board' started by Budget36, Dec 17, 2019.
  1. Yes back in the day it was STP and 10 W 40 Valvoline. Now its STP or Lucas and 15W40 shell Rotellatt. I used to laugh at those guys who used a FRANTZ toilet paper aux oil cleaner. I bought one at a auction for $1 and tried it. Im now convinced it does what the manufacturer claimed.
  2. I was taught the use atf on the rings. The same guy taught me to pull the new bearings out of the box and with a shot of wd40, take a grey scotch brite pad and clean them. Then clean them with brake cleaner and ***emble with ***embly lube. He told me the micro scratches helped in lubrication. He also wiped every cylinder out with a white cloth, for one it showed dirt, but it also helps feel any rough spots. Maybe he was crazy, i don't know. But i still use atf on my rings when i build an engine
  3. BamaMav
    BamaMav
    from Berry, AL
    I have always used pure STP on the cylinder walls, nothing on the pistons other than the 50/50 oil/STP mix I wiped down the ring compressor with inside. Used white grease on the cam, lifters, rods and main bearings, wiped the seals with the 50/50 mix. For oil it was usually Pennzoil 20w40, sometimes I used Havoline 20w40, whichever I had. Never had a problem.
    Boneyard51 likes this.
  4. saltflats
    saltflats
    from Missouri
    Spent the day with my mom for Christmas, she dug out a box with some of grandpa's stuff.
    Got this keychain I thought was kinda kool.
    Tickety Boo, Boneyard51 and Deuces like this.
  5. 57 Fargo
    57 Fargo
    As mentioned previously the idea behind dunking the pistons is to lube the wrist pin
    Tickety Boo likes this.
