Technical Ball joint tool question
Discussion in 'The Hokey Ass Message Board' started by 66, Mar 9, 2015.
  1. 66
    66
    from usa
    I have this New Britain # 476 NH , 3/4" Drive Ball joint socket. It is about 1 3/4" inside measure (flat to flat).Anyone Know what car it is used for? It appears too small for the Mopars of the 60's & 70's Thanks All!
  2. gimpyshotrods
    gimpyshotrods
    Not sure, but I used to work at New Britain General Hospital.
    It sure sounds like the aforementioned Mopar ball joint.
  3. studebaker46
    studebaker46
    i4tis probably 4the upper ball joint t4ool
  4. gimpyshotrods
    gimpyshotrods
    According to my research, that socket would be 1-59/64", which is decimal 1.921875"
  5. 302GMC
    302GMC
    from Idaho
    Corvair -F-85 -Buick Special - Tempest before '63 ...
  6. stillrunners
    stillrunners
    from dallas
    there are two mopar sizes.....the early Darts/Val's were smaller.....later were bigger....
  7. 66
    66
    from usa
    I thought I would ask again, Any one Know what cars or trucks use this socket?? New Britain # 476 NH
    I still have it. Is it for a Corvair or other GM product??
    Thanks All
  8. Mr48chev
    It's too small for the Cadillacs with a screw in lower ball joint. For some reason I never worked on a Corvair front end so I'm not sure what they have.
    There were/are a couple of them on Ebay but no more info than what you already have.
  9. gimpyshotrods
    gimpyshotrods
    Mopar A-Body upper. 1-25/32 (1/32 over 1-3/4", or 0.78125)
  10. BobMcD
    BobMcD
    Corvairs did not use threaded ball joints. The uppers were rivited from the factory and the lowers pressed in.
