Ball Joints
Discussion in 'The Hokey Ass Message Board' started by blowby, Jul 23, 2013.
  1. blowby
    blowby
    from Nicasio Ca
    I just purchased a pair of NOS ball joints for the Corvair front end in my heap. One is nice and tight, the other has about .010" up and down play and also wobbbles side to side. They are bone dry. Is this normal?
  2. Rusty O'Toole
    Rusty O'Toole
    Seems to be. Some Ford ball joints have up to 3/32" and are within spec. The grease takes up the slack.
  3. HOTRODPRIMER
    HOTRODPRIMER
    That's normal for dry joints. HRP
  4. blowby
    blowby
    from Nicasio Ca
    OK, thanks guys!
  5. Mr48chev
    Grease the hell out of them before you drive it.
  6. Delray
    Delray
    I never had a new ball joint that displayed any slack. The ball studs always needed moderate effort to move.
  7. black 62
    black 62
    from arkansas
    normal ---grease them ...
  8. models916
    models916
    The tight one will loosen up real quick.
  9. stimpy
    stimpy
    what little grease they put in them drys up while on the shelf . and the looks of the one its been sitting a long time ... on the lowers , grease them ***embled ( spindle mounted ) with no weight on them ( a arm supported wheel off ground ) first then lower them and see if it will take another pump as the weight of the spindle will open the surface between the ball stud and seat allowing grease on the dry surfaces
