Hot Rods Ballast resistor
Discussion in 'The Hokey Ass Message Board' started by New Comer, Jun 21, 2023.
  1. New Comer
    New Comer
    from Virginia
    So I have been tracing all the wiring in my recent purchase of this t bucket and all the light are working, horn is working but I am just wondering why I see a ballast resistor wired in. It has an HEI distributer and I feel this is incorrect. Can someone tell me if it should go.
  2. Driver50x
    Driver50x
    An HEI should not have a ballast resistor.
  3. Mr48chev
    I'd say that the T bucket was built with a point style distributor and the HEI got installed later. Maybe even with an engine swap. You don't need or want it with the HEI.
    If the car has a resistor byp*** wire for starting leave it in place after you take the resistor out of play, A good number of ignition switches don't supply power to the coil when you are cranking relying on the byp*** wire to supply that power.
    chevy57dude likes this.
  4. New Comer
    New Comer
    from Virginia
    Hopefully the picture will upload. Here it is. When bought he said it had a 305 engine and I ran the numbers and it is a 350.
  5. New Comer
    New Comer
    from Virginia
    Hopefully the picture will show up. Not good when it comes to uploading a lot. Guess I got a lot of old school left in me.
    seb fontana likes this.
  6. chevy57dude
    chevy57dude
    Yes, agreed, straight voltage to the HEI.
  7. squirrel
    Yeah, pull that stupid HEI out of there, put in a point distributor, and then you can use the ballast resistor as it was intended.
  8. mohr hp
    mohr hp
    from Georgia
    Right, That stupid reliable high voltage basically maintenance free HEI. Gotta get rid of that!
  9. squirrel
    I've never been stranded by point ignition, but I have by electronics...
  10. ChrisBlair
    ChrisBlair
    From '89 to 2020 I had a 1970 Buick. In '91 I put in a Buick 455 with HEI.
    Daily driver until '98, then spring/summer car
    Never. Ever. Ever had a problem with HEI. I put 375,000 miles on that car. 300K must have been with the HEI. I'd rely on it all day even today. Stab it in, forget it.
    2OLD2FAST and firstinsteele like this.
  11. squirrel
    Yup, quite the opposite of a traditional car, that lets you play with the ignition system regularly, and build up a nice working relationship.
  12. Fogger
    Fogger
    I bought a new Chevy Van in '75, first year for the HEI. Went about 20K miles before it quit. I installed a new Delco single point with a ballast resister and put another 200K miles on the van. I now have the same single point distributor in my '55 Chevy. As Squirrel stated a points distributor can be fixed on the road and not leave you stranded. BTW the HEI is not traditional.
  13. Yep. Dang things will NEVER catch on. I don't know what they were thinking.:rolleyes::rolleyes::rolleyes:. LOL
    Ben
  14. clem
    clem
    Yes - definitely for this forum, which is 1965 or older……:)……..but you already knew that……….
    X38 likes this.
  15. I'm going to use a 1977 Ford Duraspark system with my 351W and it calls for a resistor wire in the system, which I've gotten. I have read that I need this wire or I will burn out the coil, so it's going in. Anyone know whether and why I need this wire in the system?
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    That thick seat back is costing you leg room !
  17. '29 Gizmo
    '29 Gizmo
    from UK
    The duraspark is an inductive discharge system. If the coil had a balast resistor then this needs to be retained. CDI systems do not.
    osage orange likes this.
  18. vtwhead
    vtwhead
    hate those thumnail pics
  19. bobkatrods
    bobkatrods
    from aledo tx
    I have been on the side of the road with both HEI and Points, Shorted condenser with points and bad module with HEI. However, I carry points and condenser for my point distributor and a module for the HEI one,replace on side of road.
    2OLD2FAST likes this.
  20. squirrel
    Yup...wouldn't have helped the time the pickup coil quite working, though.
    If we were anywhere besides the HAMB, I'd be cool with that electronic ****.
    dogwalkin and bobkatrods like this.
  21. New Comer
    New Comer
    from Virginia
    So I just finished checking some more wiring and I tracked out the ballast resistor wiring and it was cut out but left in the middle of the harness so I pulled it out. Guess it wasn't being used. I also found where PO had splice in a different color wire going to the distributor so I will be changing that one out for the proper size and color. Found out the fuse box is a Painless fuse box but he had ran his own wire. Believe for now I can use it and just straighten out any issues. All lights, horn, and electrical seems to work just a couple of under sized wires and I will be adding an engine ground and a frame ground.
    clem likes this.
  22. Thanks for your insight. I'm gathering the pieces I'll need to hook this all together to break in the engine and AOD transmission. I'm taking my time, wanting to do it right the first time.
  23. New Comer
    New Comer
    from Virginia
    I think you are 100% correct but we are only 5 foot 7" so I believe we are okay. It is very comfortable I know that.
    Driver50x and clem like this.
  24. New Comer
    New Comer
    from Virginia
    I okay with you 100%. I am going thru everything on this as I don't know machine. There are thinks I want to do to this but want to get it running correct first.
  25. jimmy six
    jimmy six
    Not without a condenser it can’t. Stranded many years ago and a few years ago both with condensers. Both those were towed home. The only HEI that ever quit was a 1969 3/4 ton pickup and the extra rotor in the glove box fixed it.
  26. bobkatrods
    bobkatrods
    from aledo tx
    Luckily never have had a pickup go bad, I run a MSD with the points now. Easy to byp*** if that goes bad.I grew up on points and traveled many miles on them. Still have my Kal equip dwell meter.. the 40 in my AV is getting points with MSD shortly.
  27. 2OLD2FAST
    2OLD2FAST
    from illinois
    Since GM didn't use the HEI until 1974 , something e!se must have stopped your '69 ?
  28. ChrisBlair
    ChrisBlair
    Well..my '70 had a '74 engine with a '74 HEI staring in 1990
    I think he's saying that the vehicle was a 1969 model, not that he had HEI in 1969
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    Anybody's guess ??
  30. jimmy six
    jimmy six
    Opps my 73’ 454 crew cab…remembered the wrong truck.
