Hot Rods ballast resistor
Discussion in 'The Hokey Ass Message Board' started by VSO737, Apr 17, 2013.
  1. VSO737
    VSO737
    1930 Model A build........................
    Looking for IDEAS of where to put the BALLAST RESISTOR.
    I DO NOT want it on the FIREWALL............
    Thanks,
    Mike
    :cool:
  2. Bruce Lancaster
    Bruce Lancaster
    Depending on what resistance your coil requires, Echlin and Standard still sell replacement resistance wires for a variety of applications...on most of the cars produced in the last 15 years or so of point ignition the resistor was this special wire rather than a separate resistor unit, and of couse it would just replace the normal feed wire to the coil.
  3. Russco
    Russco
    from Central IL
    Be careful where you hide it because they can get smoking hot at times or you can just use an internally resisted coil.
  4. prewarpete
    prewarpete
    get a coil from a old VW and you wont need a resistor that's what i did
  5. flatjack
    flatjack
    I used the resistance wire method in my 39. Been on for 20 years now. I pirated mine out of an old 60's wiring harness. As Bruce said, you can still buy them if you ana find a parts guy who will look it up. Also available on that auction site.
  6. Pete1
    Pete1
    from Wa.
    There are lots of coils available that do not require a ballast.
  7. scrap metal 48
    scrap metal 48
    Put it on the back side of the firewall...
