Bandsaw pulley calculation question
Discussion in 'The Hokey Ass Message Board' started by Chris Casny, Sep 23, 2008.
  1. bct
    bct
    jack shaft
  2. You want 250 FPM. A 12" dia. bandsaw pulley is 12 x 3.14=37.67" dia.
    250 x 12=3000" per minute. 3000 / 37.67=79.6 RPM.--So---call it 80 RPM to get a 250 FPM blade speed.
    Your motor turns 1750 RPM 1750 / 80= 22---You want a 22:1 ratio.(overall).
    Lets do it in 2 equal stages. Square root of 22 is approx. 4.7
    2" motor pulley x 4.7=9.4"" jackshaft pulley --thats the first stage reduction.
    Put a 2" pulley on the other end of the jackshaft pulley, and a 9.4" pulley on the bandsaw.---Thats your second stage of reduction.
    So ---Here is the proof
    1750 RPM motor divided by 4.7=372.3 RPM at jackshaft.
    372.3 RPM jackshaft divided by 4.7=79.22 RPM at bandsaw.
    79.2x 12 x 3.14=2984" per minute blade speed
    2984 divided by 12=248.7 foot per minute blade speed.
    You probably can not get a 9.4" pulley, so try for either a 9.5" dia pulley or a 10" dia pulley----It won't change final speed enough to matter.
  3. d2_willys
    d2_willys
    from Kansas
    400 dollars on a motor, wow. maybe a speed reducer from Grainger would do the trick. Can't be too much, hell of alot less than 400 dollars
  4. "I value your contribution to the HAMB greatly, but at this moment I will not accept any more negative feedback"
  5. d2_willys
    d2_willys
    from Kansas
    good luck with the pulleys
  6. jj mack
    jj mack
  7. 39cent
    39cent
    from socal
    there was an article in a old rod magazine that showed doing just what you want to do , I think he got a pulley from a clothes dryer, just a thought???
  8. BigVinDaddyMac
    BigVinDaddyMac
    I think I like the swiping a jackshaft off of a drill press idea best so far.
    brianangus's pully sizes will work jim dandy.
  9. 39cent
    39cent
    from socal
  10. river1
    river1
    ok i got this from "the home shop machinist" magazine jan/feb 2004
    on your drwing bottom to top
    motor pulley-- 1 1/2
    to a
    6 in pulley
    on a jack shaft with a 1 1/2
    to a 12 pulley
    with their 13.75 in saw wheel their math shows 194 feet/min
    they also show the math for going straight from the 1 1/2 to the 12 saw wheel pulley will give you 776 feet/min
    grainger has the pulleys
    there is also a story in american rodder oct 1993 if you have one in your stash.
    i'm in the midst of doing the same thing
    hope this helps
    later jim
  11. ray
    ray
    from colorado
    dude's just trying to help.
    even seemingly bad ideas can lead to good ones. gear reduction units are NOT cheap. what IS cheap though is an old manual transmission. find the smallest one you can get for next to nothing, and you can have slow speeds for stainless, up to fast speed for blasting through wood when need be. you could even use the gear box from a riding lawn mower.
  12. I have seen it done using an old car transmission, off a 4 cyl. car.--once you get the bell housing and tailstock off, the actual ****** is quite small.--Problem is, you can only get a maximum 4:1 reduction out of them. This means that you need one pulley and belt set between the motor and input shaft, and a second pulley and belt set between the output shaft and the bandsaw shaft. It does however give you the option of higher speeds if you need them simply by shifting the ****** into a higher gear.
  13. d2_willys
    d2_willys
    from Kansas
    Thanks Ray, at least I got the calculations right.
    Being "positive", try getting a multi-size pulley with 2" and 6" on each end and then mount to one end of a shaft/bearing ***embly. I am sure you can find this in the Grainger book. Hook the motor belt to the 6" end and then the saw belt to the 2" end.
    This should give you the 3:1 reduction needed.
    Sorry if I offended you in any way.:cool:
  14. Kustomz
    Kustomz
  15. movin/on
    movin/on
    I've used a transmission out of a riding lawn mower to get big reductions in RPM's and also to have multiple speeds. Junk riding mowers are not too hard to pick up cheap. Some already have a pulley from a belt drive from the gas engine.
    It's more fab work but if you need to mount pillowblock bearings for a jackshaft -- fab work will be required for mounts anyway.
    Movin/on
  16. hobbyjp
    hobbyjp
    from socal
  17. Halfdozen
    Halfdozen
    Here's my bandsaw:
    An old Delta Milwaukee 14" from the '30's or '40's. I slowed it down to cut metal with a 19.5:1 gear reduction mounted on a simple angle iron frame below the saw. There's a further 3:1 reduction (pulleys) between the motor and the gearbox input, and two sets of pulleys on the output and the saw, to give two final speeds- about 90 ipm for thick/ tough steels, and about 200 ipm for thin steel, aluminum, wood, etc. The little idler pulley is needed to tension the belt on the faster speed.
    Try used machinery dealers and rebuilders for an inexpensive reducer.
  18. ago
    ago
    from pgh. pa.
    You want to get Bi-metal blades for cutting steel. there not cheap about $20. but they last a lot longer. It has a hi-speed edge welded to a flexible back. I have a jack shaft on my band saw, 2 pulleys on the electric motor, when I want to cut wood or aluminum I just switch the belt to direct drive on the motor and take up the belt slack with a spring loaded idler.
    Ago
  19. Bad Bob
    Bad Bob
    from O.C. Baby
    Is it me,or is there a lot of band saw issues,the last couple days????
  20. Yeah Bob! I asked about bandsaw blades last night!
  21. Bad Bob
    Bad Bob
    from O.C. Baby
    hahaha! Hadn't seen the word "bandsaw" on the HAMB before,and then saw it 4 times in the last 24hrs,LOL.....
  22. jc555247
    jc555247
    quick thinking I would say ( 2:1725 :: X : 200 ) them multiply 2 X 200 and then devide the 400 into 1725 and I would say try a 4.25" diamiter pully. You could also try an adjustable pully
  23. Did you quote someone else on this? This would come in handy those times someone gets under your skin on here.
  24. flatford39
    flatford39
    I am in the middle of doing this myself & would like to know how yours turned out. I think the system by brianandgus is probably right but would appreciate some more feedback from you.
  25. budd
    budd
    any metal band saw i have seen used a primary reduction that had steped pullies and then a secondary reduction , this is so you can change you band speed, not unlike a drill press.
  26. Flatford39--My system worked out great---I use it every day.---Brian
  27. 40streetrod
    40streetrod
    from nj
    my 2 cents worth,
    I would use a Variable speed drive pulley with a adjustable motor base.
    that way you just crank the handle on the motor base to speed up or slow down the saw just like on a DoAll band saw.
    some mini bikes used them as a clutch.
  28. 40streetrod
    40streetrod
    from nj
    something like this and I'm not saying to BUY THIS ONE, it's just another way to skin a cat.
    <TABLE cellSpacing=7 cellPadding=0 border=0><TBODY><TR vAlign=top><TD align=middle>[​IMG]
    </TD><TD align=left>218352A - Torq-A-Verter, 3/4" Bore 12 Teeth, #35 Chain Torque Converter
    The Torq-A-Verter is a fully automatic variable speed drive system (torque converter). There are no gears, no complicated controls or levers and neither manual shifting nor clutching is involved in these systems. The unique design of the movable face in each driver and driven member causes automatic infinite variation and thus smooth shifting action between the system's low and high range in immediate response to changing load and/or travel conditions..with constant optium ratio between engine and drive wheels ensuring that you get the use of all the power your engine develops. Since ratio selection and "down-shifting" is automatic, braking and vehicle control are enhanced. The Torq-A-Verter system engages at 2200 rpm. As the engine throttle is "opened" the drive belt engages, driving the driven unit at it's largest diameter. This is the most powerful ratio of the system (2.7:1). At the highest speed (overdrive) and lowest load demand the driven unit pulley flanges are wide open providing the smallest possible belt contact diameter. The drive unit pulley flanges are closed to provide the largest possible belt contact diameter. This gives the system an overdrive ratio of .90:1.
    Replaces OEM #: 218352
    Suggested Retail Price: $208.25
    Our Price: $169.99 </TD></TR></TBODY></TABLE>
  29. That's mine:D
    I did the jackshaft, and it turned out great. I cut many miles of steel, since I did the whole set-up.
  30. flatford39
    flatford39
    Brianangus
    Your calculations worked perfectly. I did the jack shaft today on my wood cutting band saw using 2" & 10" sheaves & I was able to cut thru some 1 1/2 x 3/16 angle iron with a really screwed up blade quite easily. Going to order new blades later today.
    Thank you for the help & direction.
