Can anyone recommend a Ford Model A Banger builder in Australia? Preference would be for someone in West Oz, but anywhere in Australia would suffice. Looking to rebuild my engine with counter-balanced crank, fully pressurised, inserted bearings, touring cam etc. Anyone have any recommendations?? Thanks
Try your Early Ford Club- surely there's some Model A restorers in WA. Colin Smithson here in Vic has a worked banger with OHV in a Model A roadster pickup which can keep up with the flatheads and OHV's on a run. Don't know who built the engine tho.
Hi Waxhead You can skip Dandenong Rebores the old guy (old bert ?) that knows his stuff there has retired Give a call sometime
If you need a crank there is one for sale on HAMB now. http://www.jalopyjournal.com/forum/showthread.php?t=840479
G'day, Egge Machining in Dookie NE Vic did my 8ba, they are well versed in early engines, when I dropped off the flatty they had 4-5 T model Bangers waiting work. They do babbit bearing's etc, so I'm guessing they would certainly be up for fitting inserts... They are not too far from here, & if you got excited I could probably do a deal on an A banger block, and drop it off... just a thought. Steve Plemming is his name, 03 58286250 Cheers Glenn
Glenn, thanks for the offer, and info. I currently have a running A banger, but will be looking to give the engine a freshen up in the future.............so hopefully don't need another block, but will keep that in mind. Thanks.
