Technical Banger electrical help
Discussion in 'The Hokey Ass Message Board' started by Matthew Davis, Aug 9, 2024.
  1. Matthew Davis
    Matthew Davis
    im having some electrical issues on what seem like it should be so simple. Im hoping someone here has a easy answer for me. initially had a set of worn points and the car didnt want to start, replaced the points and the rotor. when i did this it fired right up and ran for about 5 minutes then cut off and doesn't want to start again. ive tested everything and i have good spark at the points, spark off the coil but nothing to the plugs. the rotor is definitely touching the cap and the gap from the rotor to the terminals in the distributor is like .027
    what am i missing?
  2. G-son
    G-son
    from Sweden
    Try the old rotor. May be cracked internally, grounding out the spark directly to the distributor shaft.
  3. BJR
    BJR
    If the cap has a carbon contact it may be missing.
  4. d2_willys
    d2_willys
    from Kansas
    What about the coil wire from coil to disty cap?
    Hotrodmyk likes this.
  5. Matthew Davis
    Matthew Davis
    the carbon contact is there, i can get a good spark from the contact to a headstud. i would think that rules out the contact and the coil wire.
  6. adam401
    adam401
    I’m going to say bad condenser. I’ve got a couple banger cars and my experience is faulty condensers are a real pain in the *** to diagnose and give inconsistent headaches haha. The 2 most common problems I e had in 25 years of these cars are the armored cable from the ignition to the distributor and condensers
  7. ClayMart
    ClayMart
    Not familiar with these distributors but is it a simple matter to temporarily byp*** the condenser to see if that fixes the problem?
  8. Hotrodmyk
    Hotrodmyk
    Check coil wire to cap for corrosion at both ends, especially at dist cap.
  9. Matthew Davis
    Matthew Davis
    ive tested the condenser, ill check the coil wire to the cap again when i get home but i can the cap to spark directly to a headbolt if i pull it off the distributor body
  10. Matthew Davis
    Matthew Davis
  11. Budget36
    Budget36
    So spark out of the coil, but not out of the wires?
  12. Matthew Davis
    Matthew Davis
    yes, i cant make any sense of it
  13. Budget36
    Budget36
    Does the rotor spin?
  14. Budget36
    Budget36
    I ***ume it has a rotor?
    firstinsteele likes this.
  15. tb33anda3rd
    tb33anda3rd
    rotor shorted to the distributor shaft?
  16. Matthew Davis
    Matthew Davis
    rotor does spin, i have a half open top cap for setting timing, it cant short to the shaft.
    Budget36 likes this.
  17. I can relate to that! Found mine in my pocket once.
    ben
    jet996, G-son, twenty8 and 1 other person like this.
  18. Zax
    Zax
    '28phonebooth likes this.
  19. Hotrodmyk
    Hotrodmyk
    With the lower plate issue, you get no spark at all. He's got spark out of the coil. Not much left in the system. Got to be cap or rotor? Yes???
