Banger Firing Order Question
Discussion in 'The Hokey Ass Message Board' started by tjm73, Aug 31, 2006.
  1. tjm73
    tjm73
    I've been looking for this info here and on other place online, but can't seem to find it...... Simple question with a hard to find answer it seems.
    I was studying a pic of a Banger crankshaft and it looked like they fire cylinders 1 and 4 at the same time then cylinders 2 and 3 at the same time. Is that right? Or do they have a different firing order?
  2. Mike
    Mike
    I'm guessing you're asking about old flat head bangers (T's, A's & B's). Standard firing order is 1,2,4,3.
    (edit) Duh, now the picture appears, after my response.
  3. Bruce Lancaster
    Bruce Lancaster
    And--your query comes from the fact that cylinders attached to that crank will obviously go up and down in pairs, I think. Remember that a full cycle of everything is 720 degrees, not 360!! At the time one cylinder is at TDC ready to fire, its companion is at TDC finishing up the exhaust stroke--they are running 360 dgrees out of phase, which puts them in the same place but with different employment...
  4. tjm73
    tjm73
    Yes, I am aware of that but wasn't sure if firing in pairs gave the Model A/B engine it's distinctive sound or not. The answer is no, it's the 360 degrees out of phase that gives it it's sound. Thanks for clearing that up for me. :D
  5. revkev6
    revkev6
    from ma
    Most 4 bangers have a similar crankshaft setup to the model A and have a similar firing order. the thing that gives it the sound is the fact that it is a flathead and is unbalanced.
    12k rpm bike motors have the same firing order.....
  6. Artiki
    Artiki
    from Brum...
    Just in case you forget the firing order, print this off.....
