Banger Question?
Discussion in 'The Hokey Ass Message Board' started by Dynoroom, Nov 6, 2010.
  1. Dynoroom
    Dynoroom
    I've seen OHV conversions before but I've never seen as much "verbage" on a rocker cover before. Was this common?
  2. The37Kid
    The37Kid
    VERY early version of the Miller Schofield/Cragar head, I think this is the reproduction head & cover. I had an original and MILLER was ground off, there may be as many as 3 other type covers. I'm sure someone will post photos. [​IMG]
  3. RichFox
    RichFox
    My Morton & Brett says Morton and Brett Indianapolis, Indiana. Not quite the amount on yours but a lot compared to after market valve covers today.
  4. Dirtynails
    Dirtynails
    from garage
    you should realise that these heads were designed when the car was still a new(ish) device and knowledge about running cars was not that easy to come by. Most engines,especially truck units carried details cast into them about tappet clearance,recommended oils etc . Today most folks wouldn't know what was under the hood,let alone worry about the type of oil in their car so you get a little fed mandated sticker stuck under the hood someplace with tune up specs. Even that is redundant on cars built after 2004 .
  5. that's a keeper.
  6. 4-port Riley
    4-port Riley
    Most just had their name cast in the cover, the exception is the Miller/Cragar pictured above. There must have been 50 OHV heads made for the A/B Ford.
