Projects BANGER WIZARD IN LAS VEGAS....NEEDED!!!
Discussion in 'Traditional Hot Rods' started by 2FORCEFULL, Apr 15, 2024.
  1. ALLDONE
    ALLDONE
    thanks for all the replys and suggestions..still need help..
  2. brokenspoke
    brokenspoke
    Correct dip stick, possible too much oil?
  3. ALLDONE
    ALLDONE
    I kinda thought that also, but it's seems toleak more with the 7-1 head, so maybe too much crank case pressure ???.. doesn't seem like that much of a deal to pull the motor, but guess no one in vegas wants to do it
  4. ALLDONE
    ALLDONE
    I'D really like to stay with the banger as it has lots of power and lots of cool stuff, but,.. seems like it might end up a flathead.....
  5. ALLDONE
    ALLDONE
  6. ALLDONE
    ALLDONE
    so heres my thinking..... there too much crank pressure...I gutted a oil filler cap,..took the foam and baffel out... it has the ****** to go to the air cleaner , it still has the 2 baffels in the filler tube, and the filler tube is for an A.. not B... I'm wondering if the reason for the bigger tube was to let more air out??? other wise why did ford make them bigger in 32???.... any way the tube goes up hill to the carb so hoping it doesn't **** oil up to there... I reved it to the moon and it hot the k&n filter clean across the garage....so I pulled the plugs.. and poured a few ounces of marvel in each hole.... maybe compression rings haven't seated???? no smoke so oil rings are good..
    next... would it be easier to pull the trans and flywheel???? rather than pull the motor???
  7. ALLDONE
    ALLDONE
    ALSO LOOKING FOR SOMEONE IN VEGAS THAT KNOWS HOW TO TUNE AND MAKE BANGERS RUN GOOD????
  8. 29Sleeper
    29Sleeper
    from SoCal
