Technical BANGHER CARBS, STROMBERG , OR???
Discussion in 'The Hokey Ass Message Board' started by 2FORCEFULL, Sep 24, 2024.
  1. ALLDONE
    ALLDONE
    I wanna put 2 carbs on my B Bangher motor...is there any other choices for carbs???
    I don't wanna run 97's, I have a Zepher twin carb manifold, so what carbs should i get??
  2. Might I suggest a pair of Webbers?
    2FORCEFULL likes this.
  3. ALLDONE
    ALLDONE
    which ones... years ago I put a holley weber on my 235 6 cylinder, boy did that wake it up, and mpg went to over 20
  4. I was thinking maybe a couple of their side draft models. That or the down draft versions
  5. Kiwi 4d
    Kiwi 4d
    97s though will bolt right on to the zephyr manifold. But you say you don’t want 97s.
    Steves46 and 2FORCEFULL like this.
  6. The 81's used to be used a lot (from the Ford V8 60). Try posting on Fordbarn.
    Charlie Stephens
    NoSurf, 2FORCEFULL and Outback like this.
  7. ALLDONE
    ALLDONE
    so, the way I see it, 1 -97 is too much carb... and 2 is way too much...???
  8. ALLDONE
    ALLDONE
    I have 97's, but isn't that way too much carb for a 4 bangher??
  9. ALLDONE
    ALLDONE
    I got sticker shock when I seen the price...1200 for 2 carbs??? seems that there must be 2 one barrels out there that would work with out over carbing the motor.... the edlebrock 94's flow even more than the 97's.... correct???
  10. ALLDONE
    ALLDONE
    I could build a 2 carb split manifold, if I could find two carbs that flow to match my motor.... even make it a one piece that is part of the header...
  11. ALLDONE
    ALLDONE
    anty one know for fact the CFM of the most popular 3..97's, 81's and 94's ?
  12. justabeater37
    justabeater37
    Small base Rochester 278cfm
    stromberg 48 175cfm
    stromberg 81 135cfm
    stromberg 97 150cfm
    stromberg LZ 160cfm
    holley 92 142cfm
    holley 94/59 155cfm
    holley 94/8ba 162cfm
    holley egc 185cfm
    Copied from another thread
  13. ALLDONE
    ALLDONE
  14. ALLDONE
    ALLDONE
    many thanks....2 81's =270 cfm... vs 1 97 @ 150 cfm... if 1 97 is too much, then 2 81's is way too much???
    end result for the labor of love is to put 2 carbs(for the hot rod look) that actually work better than stock..
    like said... i can fab a manifold... and 2 one barrels seems like the way to go ????
    heres the motor
    I could make the manifold all one piece with the header, and get rid of all the hokey stuff
  15. ALLDONE
    ALLDONE
    I'm missing some info.... how many C.I. is a b banger motor, and whats the max rpm??
    and if you know... what CFM carb should you use
  16. ALLDONE
    ALLDONE
    To determine the total CFM (Cubic Feet per Minute) needed for your Model A 4-banger with dual 1-barrel carburetors, you can use the following formula:
    CFM=3456CID×RPM×VE
    Where:
    • CID is the cubic inch displacement of the engine.
    • RPM is the maximum revolutions per minute.
    • VE is the volumetric efficiency (typically around 0.85 for naturally aspirated engines).
    For a Model A engine, which has a displacement of 200 cubic inches (CID), and ***uming a maximum RPM of 3500 and a VE of 0.85, the calculation would be:
    CFM=3456200×3500×0.85≈172 CFM
    Since you are using two carburetors, you would divide this total by 2:
    CFM per carburetor=2172≈86 CFM
  17. 51 mercules
    51 mercules
    I'm running 1 Stromberg 81 on my banger. Does fine! [​IMG]
    Speccie, 51504bat and 2FORCEFULL like this.
  18. ALLDONE
    ALLDONE
    so according to this the 97 should be close to perfect...?
  19. ALLDONE
    ALLDONE
    I wonder if the b motor needs a bigger carb than the A
    51 mercules likes this.
  20. PotvinV8
    PotvinV8
    Ford thought so. A 'B' carb has a venturi size of 0.866-inch ID versus the 'A's 0.846-inch.
  21. carbking
    carbking
    I believe you need a "divide" instead of a "multiply"
    CFM = (CID times RPM times VE) divided by 3456
    This works halfway decently on 4 cycle engines with 4 cylinders and a plenum intake; it works better on 6 and 8 cylinder engines with a plenum intake.
    If the intake is an IR design (2 siamized runners) then you need to multiply the result by 2.
    If the intake is an IR design with 4 individual runners than you need to multiply the result by 4.
    I personally feel you are optimistic on VE for a Model A Ford engine.
    As far as some common mechanical power system single barrel carbs are concerned:
    1946~1948 Chevrolet Carter W-1 tag 574s flows approximately 190 CFM
    1946~1948 Willys military W-0 tag 636s flows approximatel 120 CFM.
    The above 2 examples would be rated on the 1 barrel and 2 barrel scale.
    Jon
    Kiwi 4d likes this.
  22. ALLDONE
    ALLDONE
  23. Steves46
    Steves46
    from Florida
    I have running a single 97 on my banger for almost 2 years with no problems at all. The motor runs out great.
  24. twenty8
    twenty8
    You have said over and over in other threads how good this engine performs, so why the hell do you want to f#*k with it? Seems counter-productive to me....:confused:
  25. ALLDONE
    ALLDONE
    I just want the look of the two carbs and a fabbed intake, I'm running a single 97 now....
    Steves46 likes this.
  26. ALLDONE
    ALLDONE
    cause there's no dirt blanket on me yet,..and it's what I feel like doing... I don't wanna be productive, I just wanna have fun.. there would be no such thing as a hot rod if every one thought like you...and as good as it is.... it's the slowest thing I own.... well, not as bad as the model TURD
    Speccie likes this.
  27. Model A Gomez
    Model A Gomez
    I had a B motor in my 30 Pickup with a Winfield head, Mallory distributor, header and a Holley 94 on an Ansen manifold and it ran great. The single 94 is plenty of carb for a mild banger but I'm building a 29 roadster pickup with an A motor, Snyder 5.5:1 head, FSI distributor and dual 81's. Two 81's is over carbed but I'm going to put smaller jets in them, more for looks than performance. I'm looking at the Burns manifold since I can use the stock exhaust manifold if I decide to go that way.
    ALLDONE likes this.
  28. ALLDONE
    ALLDONE
    I happen to like alot of carbs..
    and the little do hicky on the rear end
    it also has a 7 series winfield head
    Speccie likes this.
  29. twenty8
    twenty8
    You have sort of answered your own question there. It's already slow, and you might bog it down even more with the wrong carb setup. Going slower doesn't sound like hot rodding to me.....
    Your car, your choice. Let us know how it works out for you.
    By the way, bread has a lot of carbs.;)
    chlsnk likes this.
  30. ALLDONE
    ALLDONE
    I had 2 97's on a A motor with a zepher manifold....it worked... but way too fat after midrange to top end... even with the smallest jets... like 39's
