Technical Banjo identification
Discussion in 'Traditional Hot Rods' started by novaskilling, Oct 9, 2021.
  1. novaskilling
    novaskilling
    My friend just picked up what he was told was a 39 ford banjo. However it’s much different than mine. His radius rods are much shorter, the torque tube center bearing is completely different and his driveshaft does not have the slip collar onto the differential. Any help identifying what year the diff actually is would be much appreciated.
  2. FritzJr
    FritzJr
    If the driveshaft is a one piece extension of the pinion, it is probably from a Mercury. They used that design before the war. The remaining parts except for the pinion should be the same as Ford. The pictures that you show do not help to identify the year.
  3. novaskilling
    novaskilling
    Sorry hope these. An help.
  4. RAREBIKE
    RAREBIKE
  5. novaskilling
    novaskilling
    How do you tell? Wouldn’t 46-48 be open drive?
  6. RICH B
    RICH B
    Lack of Panhard bar mount and small diameter spring eyes suggest pre-war; the short bones would be like '41; but again Merc stuff is different.
    rusty valley likes this.
  7. rusty valley
    rusty valley
    46-48 pickups were open drive, but thats a mercury
    HotRodWorks likes this.
  8. 55blacktie
    55blacktie
    It's not a Gibson.
    Barrelnose pickup likes this.
  9. 42merc
    42merc
    1939 Mercury.
  10. alchemy
    alchemy
    A 39 Merc wouldn't have the short wishbones though, would it? The brakes are '42 and later, but those can be switched easily so don't judge the rest of the rear on that.
    It surely has a one piece driveshaft and pinion as seen from those pics. Did all Mercs use that, from 39-48?
  11. 4ty
    4ty
    Was not the Merc torque tube/driveshaft a few (4") inches longer than a Ford??
    Paul in CT
