Technical Banjo or 9” rearend
Discussion in 'The Hokey Ass Message Board' started by Alexanderkustoms55, Jun 18, 2018.
  1. Kinda stuck on this dilemma.. I have a banjo with 3.78 gears but kinda want to go 9” with 3.54 gears for highway driving.. I’m running a 1955 270 hemi with th350 trans.. what do you guys think?
  2. chevy57dude
    chevy57dude
    How hard are you going to hit it?
    Trad : Banjo
    Strong : 9"
  3. alchemy
    alchemy
    Hooking a 350 Turbo to an old banjo rearend is kinda silly. You aren't staying traditional, why bother with all the extra expense of the open drive on the old rear? The ONLY reason might be if you have everything else on the car that shows built with 100% old parts. If you can kneel down and see anything like a new hairpin, Vega steering, tube shocks, etc., then why bother?
    40FORDPU likes this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    9" would be my choice. HRP
  5. Beanscoot
    Beanscoot
    Or an 8". Plenty strong for that engine, and saves a fair bit of weight.
    If you like the look of a 9", it looks the same only a smidge smaller.
  6. Mr48chev
    8 inch might be easier to find in the right width though. They were under a lot of Grenadas and Monarchs from the late 70's. Gear ratio might be the issue though. It is reasonably easy to find a 9 inch truck rear with 3.5 gears but they are wide unless you get an early one.
  7. Beanscoot
    Beanscoot
    Also Fairlanes, Falcons, Mavericks and even Mustang II, but the last is four bolt.
  8. I found a 9” with 3.00 gears.. you guys think that will be ok?
  9. 19Fordy
    19Fordy
    What car is it going into? 9 inch rears are heavy and can be too wide.
    Will you have to narrow it?
  10. chevy57dude
    chevy57dude
    What kind of car? Weight? 3.00 : 1 would be ok in a T bucket, sluggish in a '54 Chevy wagon for example.
  11. DDDenny
    Depends on tire diameter and desired cruising speed/rpm.
  12. alchemy
    alchemy
    They made a couple bazillion 9" Ford rears. Don't let the ratio be the deciding factor. Find a housing that fits your needs first, then you can search for a chunk with the proper ratio. Or you can buy new R&P reasonably and swap to the exact ratio you wish.
  13. Jalopy Joker
    Jalopy Joker
    3:00 - 3:25 common for use with 350 trans
  14. brigrat
    brigrat
    from Wa.St.
    QC with 9" axles........................................................................
  15. I found a9” with 3.89 gears for 100$ going to pick it up tomorrow
  16. chevy57dude
    chevy57dude
    Now you're ****tin' in tall cotton.
    How wide is it?
  17. chevy57dude
    chevy57dude
    Are you going to divulge the type of car? Possibly a pic?
  18. slv63 likes this.
  19. oldsman41
    oldsman41
    Man that’s a pretty large gear with no overdrive.
    3340 likes this.
  20. dan c
    dan c
    nice car. if you don't like the ratio, change it. no biggie in a 9".
  21. Beanscoot
    Beanscoot
    60 inches? Aren't the wheels going to be sticking out a bit?
    3340 likes this.
  22. VonKool13
    VonKool13
    No worries, I had a 60" on my RPU and it looked great, all about the back spacing though. I used chrome reverse but don't remember the back space. looked killer.
  23. The banjo is about 60 inches is about the with of a banjo rear end and that’s what’s in the above picture and it looks perfect
  24. Beanscoot
    Beanscoot
    Well then you got a good deal on a good diffy!
  25. X-cpe
    X-cpe
    Pinto and Bobcat V6, 4spd wagons had 3.50 or 3.55 8in. rears (can't remember which). Pumpkin fits the other housings.
  26. Beanscoot
    Beanscoot
    Those Pinto and Bobcat 8" rear ends sometimes had limited slip. The axles are four bolt.
    I don't think it's only the wagons, the coupes I looked at in the junkyard years ago always had an 8" with a V6.
