Technical Banjo or 9” rearend
Discussion in 'The Hokey Ass Message Board' started by Alexanderkustoms55, Jun 18, 2018.
  1. town sedan
    town sedan
    Talk about hens teeth! Pinto parts....,
    -Dave
    Unkl Ian likes this.
  2. Beanscoot
    Beanscoot
    Yeah, they're not exactly in the junkyards anymore, but if you come across someone with a rusted into the ground one in his back forty, it might have a good differential in it.
    town sedan likes this.
  3. 392
    392
    Definitely 9"
  4. 38Chevy454
    38Chevy454
    The 8-inch 3.55 as used in Pintos and Must IIs were kind of scarce to begin with and then not a lot in the junkyards anymore. Most 8-inch in other cars have 2.80 or 3.00 gears, some older 60's have 3.25 range.
    9-inch will have easier to find and more gear ratio options. But 9-inch is stronger than required as previously mentioned
    For the cost of a Banjo open drive conversion, you could get the 8-inch or 9-inch rearend and be good. One thing to consider, if you want the 5x5.5 bolt pattern, then 9-inch from a truck has the right bolt pattern. 8-inch will be the smaller 5x4.5 car pattern, or the 4 lug pattern on the Pinto/Must II rearends.
