banjo or quick change?
Discussion in 'The Hokey Ass Message Board' started by BillyBobsSpeedShop, May 5, 2010.
  1. BillyBobsSpeedShop
    BillyBobsSpeedShop
    so if it has culver city on it how old is it?
  2. Bill Van Dyke
    Bill Van Dyke
    Google Ted Halibrand.
  3. BanjoBoy
    BanjoBoy
    Banjo for street use
    qc for racing
  4. denis4x4
    denis4x4
    from Colorado
    Here's the $150 answer plus the price of powder plating. I don't even try to explain it to the "experts". I also have a banger with a T-5 and open driveline with a Model A rear end. Great driver!
    METAL MELTDOWN likes this.
  5. Kirk Hanning
    Kirk Hanning
    Here are some pics of Spadaro's unit that he sells. It's actually a piece made through Winter's. Just as strong as a stock banjo seeing your utilizing the stock guts & axles but extremely traditional without the high $$$$.
  6. I don't know if you mentioned it, but what engine are you running? The unit from **** is fine - as long as you don't have much HP. It does not have a pinion support . . . just like the original Model A version from Halibrand didn't. The V8 Halibrand unit - like Winters, etc . . . has a pinion support . . . which makes these V8 units quite a bit stronger than their Model A cousins (but limited in HP levels as well).
    However, neither of these units can compare in strength to the 10" Winters, Frankland, Tiger, Speedway, Halibrand Champ, etc. The late-model quick changes are designed for a LOT more horsepower than even the early V8 units from Halibrand.
    It is important to match the Q.C. with the car, equipment and application. So - in the end, you need to know your engine combination, trans, weight of the car, intended usage, etc --- these factors all go into the selection of a Q.C.. If you're running 200 HP and skinny tires in a light car, it is completely different than running 500+ HP in a heavy car, with slicks and running the 1/4 mile . . . the same Q.C. does not work or last for both.
    Every one of these units is expensive . . . even if you buy one used and then throw money at it. The last thing you want to do is buy/setup a unit that will not fit your application . . . as you'll be throwing a couple thousand dollars down the ****per! :eek:
    Best of luck . . . let us know where you head on this.
  7. Kirk Hanning
    Kirk Hanning
    I completely agree with he above statement. It's going under a 34' sedan with a 241" Dodge hemi t-5 ******. The motor in stock form makes 140hp. If I see 200hp I'd be estatic, along with the skinny tires & approximate vehicle weight of 2800lbs. I think that I'll be alright.
  8. moonlight graham
    moonlight graham
    from wyo
    Winters has just released a stock looking banjo that uses 9" axles and there wedge lock center section. I think it's good for around 600hp. Saw an unmachined example at **** Sparado's boot at the GNRS.
    kidcampbell71 likes this.
