Hot Rods Banjo pinion bearings
Discussion in 'The Hokey Ass Message Board' started by cadillacoffin, May 15, 2016.
  1. cadillacoffin
    cadillacoffin
    For those of you who have rebuilt a banjo or ***embled a quickchange what is the best way to source out the bearings for the pinion? Hot rod works has them somewhere between $300-450 ish. I know bearings are expensive but was curious if anyone found a less expensive supplier.
    Thanks!
  2. Texas Webb
    Texas Webb
  3. Legendlives
    Legendlives
    Just go to a bearing supplier and quote the number from the old bearings.
    You'll find they'll have two or three 'qualities' of the bearings, don't go for the cheap Chinese ones. Use a 'known' make (SKF, Timken, etc.). You'll save $$$$$'s by not buying them through the rod shops.
  4. alchemy
    alchemy
    Aren't the back to back race pinion bearings a Ford only thing? Might not be an alternative.
  5. Mr48chev
  6. brokenspoke
    brokenspoke
    When I did my quick change I took all my bearings to a bearing supply....Cost around 110..total
  7. Dak Rat
    Dak Rat
    from NoDak
    I did one a couple years ago, timkin still makes the double race cone for the pinion. At least at that time they did.
  8. cadillacoffin
    cadillacoffin
    where does the cork rope seal go on rodsville quickchanges?
  9. Mr48chev
    The thing is that we need to come up with the Timken number for the bearing. I'd imagine you can get it though Timken, BCA or SKF if you have a part number besides the Ford Parts number 48- 4616.
  10. 55Brodie
    55Brodie
    Timken 27820D double cup.
