Projects Banjo QC build stand
Discussion in 'The Hokey Ass Message Board' started by 48stude, May 22, 2019.
  1. 48stude
    48stude
    I'm close to ***embling my banjo rear. I'm using a Winters QC center that I bought from **** Spadaro. The center section is ***embled and I don't wish to take it apart.
    Has anyone made some type of jig to attach to an engine stand that will hold things for ***embly.
    Also have any of you built a banjo QC from **** Spadaro that could offer me any wisdom that could keep me from screwing things up. Thanks , Bill P1020607.JPG
  2. Marty Strode
    Marty Strode
    A friend of mine has a large truck brake drum with a plate welded to it, with holes that match the pattern on the end of the axle housing. He bolts a housing to it, standing vertical, and stacks on the center section, with the opposite housing on top.
    48stude likes this.
  3. Automotive Stud
    Automotive Stud
    It doesn't really answer your question, but I just built mine on the floor with some cardboard to keep from banging anything up. You'll have to take the one side on and off a few times to get the gaskets shimmed right. 20170307_132439.jpg
    48stude likes this.
  4. 48stude
    48stude
    Thanks Marty, You've got me thinking . Bill
  5. Blake 27
    Blake 27
    The instructions provided with the Spadaro QC are well written and pretty specific.
    After cleaning and inspecting all your early ford parts you should replace the bearing races and seals in your axle housings. You'll have to ***emble and dis***emble a few times to get the gear spacing right.
    Take your time with the shim gaskets as they are ease to damage! DSC00626.JPG
  6. Nailhead Jason
    Nailhead Jason
    Built more than one Banjo by using a metal trash can upside down with a hole in the middle for one of the axle bells to fit in, then it just points straight up and stack together.
    48stude likes this.
  7. 48stude
    48stude
    Thanks Blake , As I go along I may ask you for some direction if you don't mind. I may need some re***urance . Is that the pipe plug that the instructions say to add? Thanks, Bill
  8. Blake 27
    Blake 27
    Here's a pic of the plug. If your planning on using the stock Ford wishbones I recommend a torque rod for strength. DSC02469.JPG
    kidcampbell71 and 48stude like this.
  9. 48stude
    48stude
    I built a torque arm to use in conjunction with the stock radius rods. Thanks, Bill
  10. Marty Strode
    Marty Strode
  11. I bi lt a 2x4 crate like stand and it worked great ! Wasn't very nice to look at but it worked!! Tardells book helps but not for aWinters ? You'll have to stand on step ladder for some of the steps ! Fun!!
    48stude likes this.
  12. 48stude
    48stude
    Thanks for the input guys . I suspect I'll be thinking about this all night. Bill
  13. 48stude
    48stude
    How much gear oil do you add and how do you determine when enough is enough? I thought I read somewhere 2" below the axle. **** Spadaro says up to the axle tube taper where it meets the bell. I stuck my pinkie finger in the hole that I drilled in the bell and I'm not sure it's long enough to feel any gear oil. Do you have a method that you are confident in? Thanks, Bill
  14. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Sorry I missed this thread the first time around. I have tried several ways to hold the rear end during ***embly. If you are going to do very many, it pays to have something like Marty showed. I have a couple of different ways I hold them. The thing with the one you are doing that makes it tough is the stock type axles. The thing gets pretty tall as you add the pieces.
    You can do the preload and backlash without the axles in and then add them after everything else is right. Also, I don't particularly like to shim with gaskets. I would rather shim behind the bearings like the big QCs. A pair of honed setup bearings also helps. Using late style push in axles simplifies this a great deal.
    The level of the gear oil should be at the center line of the two change gears, which in your case is 1 1/2" below the axle center line.
    Bruce
    HemiDeuce and 48stude like this.
