On my 34 truck build, I am running all NEW brake lines. How did you run yours for a banjo rear end? Rubber line down from cross member? Down the torque tube?
Two hard lines up the wishbones to a union on the torquetube, just like Henry did it. Rubber from the union to a bracket on the K member, then short steel line to the master.
Here’s what mine looks like^^. Used a bracket from a ‘39 or later Ford that mounts where the radius rods do for the end where the steel lines head to the rear. Left of the picture is to the front of the car
http://www.vanpeltsales.com/FH_web/FH_images/FH_brakes-pics/Flathead_Brakes_46-48system.jpg VanPelt's page shows the small yoke that holds the front of the two long lines, the fitting, and is held by the bolt at the front end of the wishbones. A very handy little piece. Not sure what year it started, but I know they were in use by mid 40's.
