Hot Rods Banjo rear shocks
Discussion in 'The Hokey Ass Message Board' started by butch27, Jun 12, 2018.
  1. butch27
    butch27
    Looking for rear light weight shock with 12" mounting distance and 9" on compression.
    also loop on both end. I've searched Monroe catalog and other catalogs '
    Help-- my shocks now are bottoming out badly. Thanks
  2. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    Monroe or Gabriel has an on-line catalog with sizes listed in the back, along with whatever style end you're looking for.
  3. butch27
    butch27
    Searched them both-- I can find the lengths need but NOT with both end as loops.
    they all seem to turn out a loop on one end and threaded rod on other. ??
  4. alchemy
    alchemy
    Look for Monroe numbers 5752, or 555002, or LE 10002 and see if they might fit your needs. They all have an L1 (loop) mounting on both ends and are 8.6 to 12.7 inches long.
  5. butch27
    butch27
    Thanks- but that gives me no extended length much past the mounted length.of 12"
  6. alchemy
    alchemy
    Sorry, I misunderstood. I thought you wanted 12" max.
  7. revkev6
    revkev6
    from ma
    maybe look at
    Monroe 5752
  8. revkev6
    revkev6
    from ma
  9. alchemy
    alchemy
  10. butch27
    butch27
    Thanks guys no luck --problem is the 12" mounted length
