Banjo rear with quickchange
Discussion in 'The Hokey Ass Message Board' started by 64ONEOFF, Nov 17, 2012.
  1. 64ONEOFF
    64ONEOFF
    from Md.
    I have seen banjo rears with what look as if the axel tubrs just bolt on the quickchange. Anyone know who sells them, and is it worth the time and $. I am running a flathead eventually. Just curious. Thanks fellas
  2. Is this what you are referring to?
    Designed so you don't have to change the whole side bell if the axle tube gets bent. Probably not necessary on the street.
  3. 64ONEOFF
    64ONEOFF
    from Md.
    Thats nice, but I have seen where its just the center section. And completely stock looking axel tubes..The housing that bolts to the center is not aluminum...You can send that to my house though...LOL
  4. cadillacoffin
    cadillacoffin
  5. 48stude
    48stude
  6. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    "I have seen banjo rears with what look as if the axle tubes just bolt on the quickchange."
    I take it you mean the axle tubes bolt onto the quick change the same way they bolt up to the stock Ford center section?
    You've probably seen the old Halibrand QC's. I think Halibrand still makes 'em. Winters Performance makes a nice one too. Speedway is a distributor.
    http://www.speedwaymotors.com/Winters-Quick-Change-Rear-End-Plain,5062.html
  7. 64ONEOFF
    64ONEOFF
    from Md.
    Thanks fellas
  8. geoking
    geoking
    http://www.wintersperformance.com/2010 Street Rod Rears Catalog.pdf
    I like the smaller unit on catelog page 7. But...the sky is the limit. Use the larger "torino" flanges" to put BIG Ford brakes on.
    Regards,
    George
  9. flthd31
    flthd31
    Here's a Halibrand V8 that's slipped into a '40 read. These were sold as kits back in the day to bolt right in your original rear.
  10. prewarpete
    prewarpete
  11. Pewsplace
    Pewsplace
    I have built several QC's with the 40/48 axle tubes. Here is a photo of my most recent.
  12. 64ONEOFF
    64ONEOFF
    from Md.
    Thats awesome, thats exactly what I'm talking about....:D
