Hi I didn;t know if someone out there would know what these things are worth.This one is complete with backing plates ,drums and drive shaft tube. It appears to be in really nice shape,also any tips on what to look for problem wise.......thanks-Joe
Is there a way to tell what the ratio is? We tried to do it the old fashion way .....but it didn't seem accurate- Joe
There are numbers stamped on the bottom of the banjo housing, the number are tooth count just divide. Also there will be a number on the turtle (speedo housing on the TT).
The main thing I look for is the bottom side bearing surface on the tube ends under the hubs if they are good and axles turn freely its likely a good rear
