Banjo rearend, Where are the numbers?
Discussion in 'The Hokey Ass Message Board' started by CaseyK, Mar 28, 2004.
  1. CaseyK
    CaseyK
    Are there numbers somewhere on a banjo rear? How do you know the difference between a model A and a V8 rear? Any info would be helpful!
    Thanks
  2. zgears
    zgears
    i think the ratio is stamped on the case neck bottom in factions?
  3. tommy
    tommy
    On the later models the numbers are stamped into the reinforcing web on the bottom of the banjo. You usually need a wire brush to find them. 9 37 would be a 4.11 I have several 32 rears. none were stamped. I don't know when they started.
  4. TomH
    TomH
    3.54 is stamp 11-39
    3.78 " 9-34
    4.11 " 9-37
    4.44 " 9-40
    4.55 " 9-41
    It's stamped on the bottom side, but if they have been run over a rock pile you can't always read them.
  5. CaseyK
    CaseyK
    How do you know what year is what?
  6. Spedley
    Spedley
    How much power can a stock banjo handle?
