Technical Banjo Steering Wheel ID
Discussion in 'The Hokey Ass Message Board' started by VintageOriginal, Jan 6, 2021.
  1. VintageOriginal
    VintageOriginal
    Can any of you wheel experts possibly ID this steering wheel??? IMG_0804.JPG IMG_0805.JPG IMG_0806.JPG IMG_0807.JPG
  2. 302GMC
    302GMC
    from Idaho
    Any splines or a keyway ? Looks like an unfinished repop ...
    kidcampbell71 likes this.
  3. VintageOriginal
    VintageOriginal
    I don’t know anything about it. I’m looking for one locally and this one is for sale, but the seller doesn’t know anything about it either.
  4. VintageOriginal
    VintageOriginal
    I found this similar one online. The guy posting doesn’t know his origins either. But they are both ‘supposedly’ antiques.
  5. There appears to be a part number on the inside of the wheel hub.
  6. continentaljohn
    continentaljohn
    If it has splines and a taper key it will be a GM type product. A taper with key is a ford product , what does this wheel have?
  7. VintageOriginal
    VintageOriginal
  8. Deuce Lover
    Deuce Lover
    Looks like 1936 Buick ?
  9. mitch 36
    mitch 36
    20201207_133418.jpg 20201207_133357.jpg It's not an early GM as they have taper and key way and two holes thru the hub for horn rods - no splines. Also the back side of the hub is extended to fit into the column not inset like the OPs. This is a 35/36 Chevy banjo or what's left of it, for reference. My guess would be a modern style repo of sorts. Mitch
    VintageOriginal likes this.
  10. VintageOriginal
    VintageOriginal
    It does look like one except for the Center hub
  11. VintageOriginal
    VintageOriginal
    It’s starting to look like that’s what it is. The hub is not like anything vintage I can find.
  12. spanglishkings
    spanglishkings
    from Napa, CA
    Since we’re on the topic of identifying banjo wheels, how about this one? I “think” it’s 38-39. Either way, I need a horn ****on for it.
    Thanks
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Don't forget, they were issued on early Beetles, some MG
    Just Gary likes this.
  14. ClarkH
    ClarkH
    Banjo wheels also came on later English Fords. In my experience, when you find an unidentifiable banjo, that's what it is.
