Technical banjo with 9" axles
Discussion in 'Traditional Hot Rods' started by JL Kustoms, Jan 28, 2019.
  1. nobby
    nobby
  2. joel
    joel
    I have the HRW axle conversion on my 41 p/u with Lincoln repo brakes. Very slick . In my opinion, no need to jump to late brakes, because the lockheed brakes would have bolted on just as well as the lincolns. If you fell the need to machine something yourself, machine the bells for HRW bearing adapters .
  3. Ken Smith
    Ken Smith
    Alliance Vendor
    We sell all the parts individually. You can pick and choose what you want.
    rusty valley and Paul like this.
  4. Paul
    Paul
    Editor
    I used the '50 Mercury bearing ends and axles in my '27 roadster.
    made noise from almost day one.
    after 7,000 miles it's time to open it back up and do it right.
    As soon as I have the funds together I'll be placing an order.
    Outback, joel and HotRodWorks like this.
  5. Distracted
    Distracted
    Jseery, I'm planning on using the 7.5 side gears for my banjo conversion, did your 7.5 gears mesh smoothly with the stock 11 tooth spider gears? HRW shows the F1 and 9" side gears being a bit notchy but don't show the 7.5 side gears in their video. Also , do you have the dimensions of the 7.5 gears that you can share?
  6. Okie Pete
    Okie Pete
    Good information gives me something to think about as I’m going in circles in the fields .
  7. nobby
    nobby
    jeep shaft dana
    mk2 wire wheel jaguar shaft
    mk2 jaguar knock off hub for the wire wheels
    its all dana 41 44 19 spline
    jeep
    f100
    mk2 jaguar
    v8 quick change
    19 spline dana spidery gears
    jeep/jag shafts
    wire wheel hubs
    1959 mk2 jag disc brakes
    stock jag wire wheels 15 or 16 inch
    16 inch wires with 6.00 firestone white walls
    got to be 3.125 wheel bearing
    flange for drums......
    run f100 10 by 1.75'' shoes with self adjusters and early style kindey bean pressings and radial fins
    hmm nice
    yes, forgot about the mgc front hubs
    MGC ROADSTER OR CGT 8 TPI FRONT RH WIRE WHEEL HUB BTB878 right hand D2B | eBay
    oh i het it
    the xk120 uses a drum that mounts from the front
    the later mk2 front hubs mount the rotor to the rear
    oh, there are 4 different front hubs
    e type 1 adn 2 is different from series 3 which must use a vented rotor rather than a solid rotor
    the xk is drum, so thats 3 versions
    hmm
    harder than it appears
    11 rotor 1'' thick is series 3 e type v12
    i wonder if they go on an early ford spindle with the f1 brake swap bearings
    do do do
