Projects Barn find studebaker
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Apr 1, 2022.
  1. It’s all there but the radiator.
  2. DC495E7E-451A-4B63-9801-A591A54C7125.jpeg 8CBD880C-E2E7-4C25-8F81-89F66A097657.jpeg
    That hunk of junk @anthony myrick posted looks like a cheap Tucker torpedo replica.
    at least we got this real one to compare it to ! :p
    cfmvw, hotrodjack33, scotty t and 2 others like this.
  3. I’ve always liked these srudebakers.
  4. Crocodile
    Crocodile
    After seeing your first post, I excitedly called my uncle in Oregon, who was the President and Commander of the Studebaker restyling club for years, although he stepped down after being called a Dictator.
    He travelled the pacific northwest buying all of the bullet nosed Starlight Studes that he could find, and then would cut the roof off and weld it back on the opposite direction. He had it on great authority that the engineers spilled coffee on the original blueprints, and it resulted in the windshield being placed in the back, so he rectified this on as many cars as possible.
    He did most of his cutting with cross cut saws, since he could find them cheaper at rummage sales than buying hacksaw blades. He had a good supply of filler rod, because his neighbor owned a plant that made coat hangers, and when a new employee would run the machines for the first time, often they would put the twist at the top in backwards, and would not meet military spec. He said that if you welded from right to left, they still worked fine.
    His cars had a strong fan base, with most of them being purchased by Barnum and Bailey or Ringling Brothers, for some unknown reason.
    The car you found has the bullet nose replaced with a light. Those were extremely popular, with the best ones coming from the Gambles store. He said they were across the isle from the accessory t***els for the Hiawatha bicycles, and were often sold out. Sears had them too, but only in 12 volt, and he couldn't afford the other 6 volts, so he wouldn't use them. You had to install them with the wheels straight, or they would come out crooked.
    He said that the car you found is the cheapest model, which is why it has a puny rear window, and therefore, less desirable, not to mention the extra doors.
    Nowadays, with builder cars harder to find, it would be worth messing with, as long as you follow a recipe for success. It HAS to be put on an S-10 frame. They are specially engineered to fit under any and all old cars. Then it needs a 350 Chevy. The late 70's models from California have the best power, because they have a big belt driver blower on them that gives you ***isted propulsion out of the tailpipe. Make sure the tailpipe exits straight out the rear, or handling could be affected if it pushes you sideways. If it has 4 bolt mains, it automatically has an extra 37.4 horsepower, too, so look for that.
    Using easily found accessories, like rusty chain and old saw blades, you can do a spiffy job of customizing it. Welding on old wrenches gives even more style. be sure to use s stick welder, and leave your rods out in the rain so your welds get some "patina".
    Do not paint it, or the value will drop. if it has too much paint, some sanding before a rainstorm will help the cool factor.
    I say "Go for it" and knock our socks off with the machine you will have in no time1
    Bleach, 302GMC, lumpy 63 and 3 others like this.
  5. nrgwizard
    nrgwizard
    from Minn. uSA
    Geez, Anthony;
    W/o bumpers, that hulk can't be worth very much. You actually gonna bother expending the effort? :) .
    Croc;
    You gotta spill all the secrets... ? Sheesh...
    Marcus...
    hotrodjack33 and anthony myrick like this.
  6. SS327
    SS327
    I always wanted one of those to make an El Camino out of. The only problem is the engine is in the back, but I figured out a work around. You raise the bed up higher. They don’t make good g***ers because like Corvair they got the engine in the back. Too light in the front. It would just keep the front wheels high in the air. It would look stupid! Them old Studes sure were cool looking. You could do so much with them.
  7. hotrodjack33
    hotrodjack33
    Yeah, I'll probably give up on my Stude project. Every time I work on it, I get Tuckered out:eek:
    catdad49, SS327 and anthony myrick like this.
  8. cfmvw
    cfmvw
  9. SR100
    SR100
    Gotta be a fake, no suicide rear doors! :rolleyes:
    cfmvw and VANDENPLAS like this.
  10. Does anyone recall the 48 Tucker Torpedo around Malden in the late 60's? I saw it several times.
