Customs Barn (Garage) Find '52 Merc.
Discussion in 'The Hokey Ass Message Board' started by kustomfordman, Apr 8, 2022.
  1. loveoftiki
    loveoftiki
    from Livonia,Mi
    Sounds great…my 54 drove like a dream…and just for the record….that car needs WW…it’s a Merc…
    RICH B, SS327 and WalkerMD like this.
  2. It needs whitewalls!
  3. loveoftiki
    loveoftiki
    from Livonia,Mi
  4. bobss396
    bobss396
    The '59 wagon is one of my bucket list cars. My dad had one, which got wrecked just before Xmas of 1963. Supposedly a 312 T-Bird engine with a 3-speed stick.
  5. kustomfordman
    kustomfordman
    Time to clean up the shop while I contemplate tire choices...blackwalls, whitewhalls, bias, radials. Points of contentions and many schools of thoughts. Meanwhile, everybody out of the pool for shop maint. Head to head. Speaking of clean-up, there has been several mentions of the Flitz brand for bright work polishes and paint. Is there any one Flitz product for both, or is it one for bright work and another for paint. I'm guessing the Merc.'s paint is a lacquer and no clear coat. PXL_20220410_172000125.MP.jpg PXL_20220410_172018154.jpg PXL_20220410_172039461.jpg
  6. 41 GMC K-18
    41 GMC K-18
    Just go to
    flitz.com
    There is a variety of different flitz products to choose from.
    On the topic of the tire choices, since the Mercury is a runner and is able to move now. You might want to make a couple of cardboard cut out templates, to spray white paint on, in the size of what ever white side wall you think you might want to invest in, tape them to the existing black wall tires, and then get some good shots of the side views of the Mercury.
    As I have stated before, this particular Mercury you now own, is equipped with black wall tires, and original wheel covers, and that slightly visible red of the wheels. That little bit of red, is a subtle element that really works with the blackwalls, but that is just my opinion. The black walls worked on the cool ranch wagon !
    At least with the white template, made of cardboard, you can then see, if the whitewalls are the way you want to go, or not.
    Again as stated, " That Mercury is one kick *** ride "
    chryslerfan55 and '28phonebooth like this.
  7. kustomfordman
    kustomfordman
    Dang-it, tires are expensive! Not debating the cost, just dang-it! Any suggestions on supplier? DiamondBack or Coker? Or is there another? I am leaning towards DiamondBack.
  8. Dos Cincos
    Dos Cincos
    Love the Merc! Nice score for sure. As for tires, I'm very happy with my Diamondbacks.
  9. kustomfordman
    kustomfordman
    Thanks for the compliments.
    A few longer trips over the past few days. The Merc. seems to be dependable so far. A little dead spot on throttle tip in....gonna change the accel. pump linkage to see if that helps. Also, seems the overdrive does not engage. I just pulled the lever while in 3rd, so not sure I am doing it correctly. Will look into this.
    Ordered the Diamondbacks yesterday.
  10. Squablow
    Squablow
    I think you have to get up to speed, then let off the gas (but no clutch) to engage the overdrive. I think if you're in the gas at RPM's the overdrive won't engage. But someone can correct me if I'm wrong.
  11. tbirddragracer
    tbirddragracer
    The overdrive operates as follows:
    Push in the lever under the dash
    Get the speed up to approximately 27 mph
    Let up on the accelerator
    The overdrive should engage
    A kickdown switch is under the accelerator
    The overdrive will drop out when the speed is below 27 mph
    The overdrive lever can be pushed in while underway,
    but never, never pull the lever out while underway.
    Love that car, I have whitewall Diamondbacks on my '57 Fliptop.
    Ernie
    chryslerfan55 and 41 GMC K-18 like this.
  12. Jones St.
    Jones St.
    You need to brighten that paint? Go back to post #7. Research that link & learn how to preserve that paint.
  13. Big Dad
    Big Dad
    I like your plan
  14. kustomfordman
    kustomfordman
    Thanks! Your instructions are almost verbatim to what is in the owner's manual. I will try again.
    chryslerfan55 and VANDENPLAS like this.
  15. kustomfordman
    kustomfordman
    Still unable to embed when the video setting is set to public.
  16. guthriesmith
    guthriesmith
    Hmm...video says I need to sign in when I click on the link. Maybe the privacy settings are what kept it from imbedding correctly?
  17. bobss396
    bobss396
    OG Ford lacquer wears like iron. I had to remove it from where I mounted my hood scoop. It was an effort to get through it. I'd say the Merc should polish up well, but not easily.
  18. 1low52
    1low52
    Love your car(and story)!
    The white wall /black wall/radial/bias debate is endless.
    It all depends on you and the look you're going for.
    I go back and forth with my cars and have decided to not decide.
    I keep sets of both mounted on my tire rack and change them for a different vibe when the urge calls.
    Your car/your choice. Love it and have fun!
  19. e1956v
    e1956v
    Alliance Vendor
    If you’re able to get both set's of tires mounted it’s like having Sunday shoes (white walls) and sneakers (black walls). I agree with 1low52, best of both worlds.
    Ron Funkhouser and 1low52 like this.
  20. kustomfordman
    kustomfordman
    Diamondback wide whites are on order. In the meantime, I swapped over the wheels and tires from the '59 for some perspective. For a minute I liked the look, but now I am over it. The rears are too big anyways....those are 17" wheels and it is over stuffed. Now my '59 is pissed at me. I look forward to the Diamandbacks on the red wheels. I did take the Merc. out for a cruise and the radials feel good. Also, the overdrive works, now that I know how to use it. The dang thing runs so smooth its hard to feel/hear the RPM change when the overdrive engages. So give me your opinions on the wheel/tire combo.
    chryslerfan55, nochop and 41 GMC K-18 like this.
  21. 41 GMC K-18
    41 GMC K-18
    As stated before, because of the black paint job, black walls really work well for your particular Mercury, IMHO.
    If your Mercury had a white roof, then I could see how the wide white walls would be preferable.
    But since you are going to use the red wheels and hopefully the original wheel covers, then to my eye, black wall tires will look great.
    As they do now in the pictures that you have posted!
    Your Mercury, is very kick ***, and it's cool that it functions as well as it does!
  22. Um....uh.....NO!
  23. loveoftiki
    loveoftiki
    from Livonia,Mi
    I’ll take the heat here....that thing needs whitewalls and please tell me you got some choice hubcaps and aren’t running red steel wheels without em? And you ordered 15’s, correct? the Aerostar springs and blocks are on the way?? It’s a Merc...gotta be cl***y... won’t take much...and ya can throw all the stock stuff back on it..should you feel the need
  24. 1low52
    1low52
    You asked for my opinion,
    It looks great both ways, but, it's a Merc. It is, and always has been, a cl***y car.
    I can hear it screaming WIDE WHITE ME! lol
    chryslerfan55 and loveoftiki like this.
  25. kustomfordman
    kustomfordman
    Wide whites and 15". Just wasting time with the switch from the '59 and wanted to get the Merc. up to hwy. speed...couldn't do that with the original bias tires that are coming apart. The black wheels and rims are going back on the '59. Planning on running the stock red wheels and Merc. wheel covers....for now. Gonna go with the dropped uprights to start. Looking into dropped leaf springs for the rear. 2.5" drop in front and maybe 3.0" in back. Gonna start on paint restoration this coming week. A light rub with clay and rub and soak with Mequires #7. Sharing window decals. PXL_20220416_235904712.MP.jpg PXL_20220416_235932443.MP.jpg PXL_20220416_235943478.MP.jpg
  26. 41 GMC K-18
    41 GMC K-18
    Way cool !
    Most impressive !
  27. loveoftiki
    loveoftiki
    from Livonia,Mi
    Sounds like a good plan
  28. kustomfordman
    kustomfordman
    Perhaps I should follow the owner's manual advise on customizing. A rear wiper? PXL_20220417_001852054.jpg PXL_20220417_001914785.jpg PXL_20220417_001935558.jpg
  29. mcnally351
    mcnally351
    from boston
    Cool project will be a great cruiser
  30. downlojoe33
    downlojoe33
    You sir, have scored a very cool car. Congratulations! To me the plan you have for it is spot on. The dropped uprights and lowered rear springs should bring the stance down nicely, and improve the ride and handling in the process. I'm a whitewall guy, and with stock hubcaps or maybe a set of Lancers (no Fiestas please) and the hint of red rims showing against that black paint, you're set. You might even check out how it looks with those skirts on. I hope you enjoy every mile.
    41 GMC K-18 likes this.
