Hot Rods Barn or in this case, garage finds still exist!!
Discussion in 'The Hokey Ass Message Board' started by Vintage Amercian Iron, Feb 8, 2019.
  1. Vintage Amercian Iron
    Been trying my hand at repairing the rust on the passenger fender. My first attempts, so learning as I go, but enjoying the process.
    IMG_2463.JPG IMG_2467.JPG IMG_2482.JPG IMG_2485.JPG thumbnail (1).jpg thumbnail 10.jpg thumbnail 12.jpg thumbnail 14.jpg thumbnail 17.jpg thumbnail20.jpg thumbnail23.jpg thumbnail26.jpg thumbnail28.jpg thumbnail29.jpg thumbnail30.jpg thumbnail35.jpg
  2. Squablow
    Squablow
    Your welding repairs look good. As long as your finished welds are flush or just slightly below flush, you'll be golden.
    Vintage Amercian Iron and lippy like this.
  3. Vintage Amercian Iron
    Thanks, appreciate the compliment and tip.
    They will need a touch more blending, but just getting close for now, as both fenders have pretty much the same issues, so a lot more cutting & welding to do.
    Once all the rust work is done, will be fine tuning the patched areas as I strip the fenders of all the old lacquer paint.
    Hope to have a busy and productive summer!
    Okie Pete and chryslerfan55 like this.
  4. Vintage Amercian Iron
    Got the patch fully welded in and ground fairly smooth on the outside. Not a perfect blend, but based on my skill level & experience, I am happy. Next up, lower section of fender brace...
  5. Vintage Amercian Iron
    This is the last of the known rust on the passenger fender!! Now have to do pretty much the exact same repairs on the driver side. But now I have a little experience, so hopefully it goes a little better.
    thumbnail40.jpg thumbnail42.jpg thumbnail43.jpg thumbnail44.jpg thumbnail45.jpg
  6. Vintage Amercian Iron
    Started on the driver side fender. Has pretty much the same issues as the passenger side did, only a little more extensive. For the first patch, due to its size, I cut a patch out of a fender I picked-up at the swap meet and fit it in place. Treated the area with rust converter and after I strip the paint, will weld it in place.
    thumbnail46.jpg thumbnail47.jpg thumbnail48.jpg thumbnail51.jpg thumbnail52.jpg
    Okie Pete and Squablow like this.
  7. Vintage Amercian Iron
    One more chunk be done!!! Will have to use some fiberglass to close some pin holes that I just can't get welded without making them worse.
    Stock Racer and Okie Pete like this.
  8. Squablow
    Squablow
    Your welding work looks very nice. I would warn against covering pinholes with fiberglass, it's a moisture trap and can make things worse. If you have some pinholes you're trying to weld closed, I find holding a piece of brass or copper on the back side when you make your tack really helps. The weld won't stick to the brass and it has less tendency to blow out with the brass backer. Even a chunk of flattened copper plumbing tubing can make a handy backer for welding up holes.
  9. Vintage Amercian Iron
    Thanks, am literally learning as I go! Not to worried about fiberglassing the few small pinholes as it will be covered on both sides by primer, sealer & paint. I have several different shaped copper backers and use them, but there comes a time when it is done, I could chase it till the entire front of the fender is weld metal stacked on top of its self vs sheet metal... I am pretty sure there are a lot more little rust holes in places that won't be seen until they want to be. Appreciate the compliment and tips.
  10. Vintage Amercian Iron
    Rust repair, just like eating an elephant, 1 bite at a time...
    thumbnail60.jpg thumbnail61.jpg thumbnail63.jpg thumbnail64.jpg thumbnail66.jpg thumbnail68.jpg thumbnail69.jpg thumbnail70.jpg thumbnail72.jpg thumbnail73.jpg
    Okie Pete, Stock Racer and Squablow like this.
  11. Vintage Amercian Iron
    Little more work on the fender before it got too hot in the shop to finish this chunk. thumbnail74.jpg thumbnail76.jpg thumbnail77.jpg thumbnail78.jpg thumbnail79.jpg
  12. Squablow
    Squablow
    Did you add the hole to the patch panel ahead of time intentionally, or was that just the piece you had handy? Curious why you'd do it that way. The work looks good, just wondering.
    Vintage Amercian Iron likes this.
  13. Vintage Amercian Iron
    The area needing replaced was around the original trim mounting hole, so I added it to the patch first, then bolted it on through the original hole and the new one to maintain original spacing and alignment. Easier that trying to go back and drill after the fact and hope to keep everything in line.
    Squablow likes this.
  14. Vintage Amercian Iron
    It is hard to see in the first picture, but the arrow in this pic is pointing to the original trim hole.
  15. Rickybop
    Rickybop
    Awesome that you're getting some good work done on your cool red '57 Chevy ht!
    You must be smiling.
    I would be. :)
  16. Squablow
    Squablow
    OK I get it. Clever, seems like it worked well.
  17. Vintage Amercian Iron
    Knocked out a little more rust work this afternoon.
    thumbnail80.jpg thumbnail81.jpg thumbnail82.jpg thumbnail83.jpg thumbnail84.jpg thumbnail85.jpg
  18. Vintage Amercian Iron
    Thanks!
  19. Vintage Amercian Iron
    Cut out and replaced a section of deeply rust pitted patch, treated with rust converter last night and just needs some primer today. Moving on the next and last part of this fender, the rear lower corner & brace... thumbnail86.jpg thumbnail87.jpg thumbnail88.jpg thumbnail89.jpg thumbnail90.jpg
    Okie Pete, Squablow and Stock Racer like this.
  20. Vintage Amercian Iron
    Driver side lower fender skin rust work started. Got run out of the shop due to the heat, but did get the patch tacked in. Finish welding and then replace the crusty brace and call that one done...
    thumbnail91.jpg thumbnail92.jpg thumbnail93.jpg thumbnail94.jpg thumbnail95.jpg thumbnail96.jpg thumbnail97.jpg
  21. Vintage Amercian Iron
    Finished the welding on the backside and coated to protect from future rust. Also cut & fitted the brace section and painted the backside with the same rust treating paint as the inner fender. Now letting cure overnight. Finish installing the brace section tomorrow, then blend/smooth the welds on the front side and that fender will be done for the time being.
    Stock Racer, Okie Pete and Squablow like this.
  22. Vintage Amercian Iron
    Calling this fender done with rust repair, moving on to the doors next.
  23. Vintage Amercian Iron
    Taking a little break from metal work and am prepping the interior for painting with epoxy primer. Started on the package tray, that glue has to be of Alien origin!!
  24. Vintage Amercian Iron
    Spent a little time cutting the jagged extra speaker hole out to nice metal and fitting a patch. Just need to weld it in next. thumbnail6.jpg thumbnail8.jpg thumbnail9.jpg thumbnail10.jpg
  25. Vintage Amercian Iron
    Finished the speaker hole repair, all welded in and smoothished over.
    Stock Racer, Okie Pete and SS327 like this.
  26. Vintage Amercian Iron
    Finished up the package tray for now.
    Stock Racer, Squablow and Okie Pete like this.
  27. Vintage Amercian Iron
    Also got the extra sheet metal around the shifter hole out of the way so I can continue prepping the floor for primer.
    Thinking about adapting in this G-Body shifter cover I have had kicking around for about 20 years. I think it would look cooler that just a shifter boot attached onto the carpet.
    chryslerfan55, catdad49 and Okie Pete like this.
  28. Squablow
    Squablow
    I believe that G-body floor shift hump is pretty rare and very valuable on eBay, could probably get a few hundred bucks for it and buy a repop first gen Camaro or Chevelle hump to cut up, and pocket a pretty large difference.
    Looks like it could be made to work and I like the idea of a hump, just don't think I'd cut that one up. If you get a repop one you can get the matching boot and bezel for it too to really look like factory.
  29. Vintage Amercian Iron
    Thanks.
    Tried in the past to sell it very cheap, and got no takers....so probably will have a new purpose in the life of a Tri-5.
  30. T. Turtle
    T. Turtle
    I know nothing about the rarity of this shifter tower but to me it looks almost there. In my case I used an... MGB item which I had to cut & shut a LOT. It fits nicely now but was a PITA so I'd say just use it, time is also a factor.
