Technical Basic Intake Manifold Construction Question
Discussion in 'The Hokey Ass Message Board' started by LeoH, Dec 14, 2015.
  1. LeoH
    LeoH
    from Reno, NV
    Well, basic in the sense that it's part of building your own multi-carb manifold. I've a single barrel carb manifold for a flathead Six, with the heat riser built into the intake manifold.
    Although I've seen many a homemade multi-carb intake manifold build, what do people do to adjust and compensate for not having that air pre-heat function originally designed? For the most part, from what I can see, it's not replaced, but I would think something would need to take the place of the pre-heat function.
    I don't know, so I'm asking.
  2. seb fontana
    seb fontana
    from ct
    Since you don't see much cold temps it won't be much of a problem for you...Here in CT where it gets cold winter DD is a pain the ***, had to box the intake in to the header to get some heat..
  3. squirrel
    it gets pretty chilly in Reno. I'd see about adding some type of heat to it, if possible.
    LeoH likes this.
  4. Jalopy Joker
    Jalopy Joker
    post a pic of manifold/motor. heat risers that I have seen either direct heat to carb choke, or exhaust g***es going through intake manifold. do not directly heat intake manifold or carb. gas is flammable.
    LeoH likes this.
  5. ol'stinky
    ol'stinky
    from New Jersey
    Aftermarket 6 cylinder intakes such as Edmunds have a p***age way that allows engine coolant to run through and heat the manifold. While that's not really for pre heating it might help a little in the regard.
    LeoH likes this.
  6. gimpyshotrods
    gimpyshotrods
    Shown from the underside. See the hose ******s for the heater hose?
    And Reno gets colder than Connecticut.
    LeoH likes this.
  7. LeoH
    LeoH
    from Reno, NV
    We are definitely cold. Finally this year, but winter is chill in' right now!
    We
  8. LeoH
    LeoH
    from Reno, NV
    Thanks for the tips. I figured there were ways, I just hadn't noticed the heater tricks on the photos I've seen before. Haven't really studied a multi carb manifold up close before.
  9. G-son
    G-son
    from Sweden
    Let he air cleaner **** hot air from a shroud around the exhaust manifold. Use during winter, remove for summer driving.
  10. stimpy
    stimpy
    you could make a small runner ( stainless pipe ) and direct some exhaust flow thru it to start it up . but to keep the manifold /carb from Icing I would water heat it as the same as the edmunds . just use the water pump byp*** hose to get the water before the thermostat or use the heater line off the head to the heater . the water heats up faster than you think ( 2-3 minutes ) .
