Bat wings and mounting?
Discussion in 'The Hokey Ass Message Board' started by Antibilly, Jan 21, 2004.
  1. Antibilly
    Antibilly
    I got a set of Bat Wings from speedway motors and they are set up at a angle? when mounting them would they lean in or out on top????
  2. Smokin Joe
    Smokin Joe
    Bottom is longer than top so the axle will lean back on the top. Is that what you're asking?
  3. Antibilly
    Antibilly
    note the angle of the wings would they lean in from the top or out?
  4. Antibilly
    Antibilly
  5. shifts
    shifts
    Mike, is that the set I sent you? Dave
  6. Antibilly
    Antibilly
    or are these just speedway defects?
  7. Antibilly
    Antibilly
    no no no these were the ones I had already ordered I was telling you about...your items are not here yet...
  8. Have you test fit them to the axle?
  9. Antibilly
    Antibilly
    Look they fit the axle MAN!!!
    what Im askinf is rather simple if you read it....do these angle in or out from the top?
    JEEEEEEEEZ!!! sometimes [​IMG]
  10. Kevin Lee
    Kevin Lee
    Super Moderator
    I think what he's asking is have you test fit them to the axle?. These questions sometimes answer themselves when you have all of the parts in one place. I'm guessing the batwing is angled like that to compensate for the "smile".
  11. hammeredabone
    hammeredabone
    You have them reversed the one on the left goes on the Drivers side looking at front of car. The axle boss'es are at an angle. The bracket part that the hairpins attach to should be perpen****ular to the ground. JFC, Mikey, you really couldn't figure that out?
  12. Antibilly
    Antibilly
    ok well I guess knowone has ever run bat wings...Ill test fit them after work and post what works best
    thanks
  13. Mutt
    Mutt
    When installed, they will be vertical, as Grimlok said, to compensate for the axle boss angle.
  14. Antibilly
    Antibilly
    GREAT!!!! thats what I needed to hear.. thanks for all the help..
  15. [ QUOTE ]
    [/ QUOTE ]
    The axle curves up at the perch bolts, right?
    Not the drop area, but the area where the perch bolt goes through.
    The perch bolt bore is not vertical, but goes through at an angle.
    Once you have it figured out which batwing goes on which side of the axle you'll end up with the back side of the batwing vertical where the radius rod bolts on.
  16. Antibilly
    Antibilly
    it all seems simple now!!!
    thanks again
  17. MBL
    MBL
    Who does your nails?
    Tim
    MBL
  18. Antibilly
    Antibilly
    FLICK you TIM!! youll never even get this far on your pre war paper weight [​IMG]
    Oh and the last time I had my nails done it was Ching Chong!! [​IMG]
  19. MBL
    MBL
    I'm already past that stage....Drive shaft in...engine in....trunk lid made...(thanks to walt)....wheels tyres...suspension...on and attatched... A set of gaskets for the engine...and a master cyl and we're ready to wreck that thing....into Jon's Miami Nice....
    Tim
    MBL
  20. Antibilly
    Antibilly
    Oh I forgot..............its been some time since Ive heard from you boys [​IMG]
