Battery box vent neded?
Discussion in 'The Hokey Ass Message Board' started by thewildturkey46, Mar 21, 2007.
  1. thewildturkey46
    thewildturkey46
    from Rice, MN
    I am using a pop cooler for a battery box,in side of the car, using a sealed battey but not an optima, just a regular 12v wet battery. Do I need to vent the battery box? There are 2 holes in the bottom with gromments for the cables to p*** thru, but are fairly tight. The lid clamps down with a rubber seal. Will I have a proble or should I drill some vent holes? Thanks, Dale
  2. Shane T.
    Shane T.
    I would port it, on mine I used the Optima battery and didn't worry about the vent. With a traditional battery you'll definetly need the airflow.
  3. 55 dude
    55 dude
    what about the drain hole they come with? you know for the melted ice.
  4. yekoms
    yekoms
    I would vent it to the outside of the car. Do the cables run out the bottom and directly through the floor?
  5. thewildturkey46
    thewildturkey46
    from Rice, MN
    yes thru the floor thru gromments, so are tight, I could drill another hole and adda tube there.
  6. 53chieftian
    53chieftian
    I would add the vent tube in the floor, then it acts like an old fashioned road draft tube. ****s out all of the fumes at speed (Which is when most fumes will be created)
