Technical Battery Boxes
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Oct 23, 2022.
  1. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I plan to locate the battery for my latest project in the trunk. Looking for ideas,suggestions, pictures of what others have done/used. Summit has a cheap one and a fairly expensive one available, but its a ways off and I'd like to see what works best before deciding.
  2. My only suggestion is that you heavily powdercoat all metal parts except for threaded items to keep the corrosion critter at bay. I'm talking at least three thick coats, best applied by starting with a 'standard' coat, then after that's fully cured pre-heating the part to 200 degrees to apply each additional coat. Cure these coats as normally. At 200 degrees, the powder will partially melt/stick on contact and if you go too heavy you can get runs. Use stainless hardware for all threaded parts with plenty of anti-seize on the threads. This will stop corrosion dead in its tracks. The coating will stain however, black will be the best choice.
    ekimneirbo likes this.
  3. chop&drop
    chop&drop
    There are a number of good polypropylene boxes available. They’re tough and you don’t have to worry about corrosion. I used one to relocate the battery in my ‘32 Tudor to behind the back seat.
    ekimneirbo, loudbang and onetrickpony like this.
  4. Deuce Daddy Don
    Deuce Daddy Don
    Use welding size cable for both positive & ground leads.
    ekimneirbo and hotrodharry2 like this.
  5. kabinenroller
    kabinenroller
    Here is how I mounted the battery in the Comet, the bottom of the box is cut out, then the box mounts to a plate that is attached to the trunk floor. Cables exit the back of the box through grommets, the small lead is for the battery tender. A perimeter bracket holds the battery in place. The neoprene hose is a vent that exits behind the rear bumper, the lid and sides of the box are lined with rubber sheeting.
    1F6B6B80-707E-40D6-B900-4830E7E1B571.jpeg F0F25D12-C7D1-4654-AF81-0287C418FE5E.jpeg
  6. MeanGene427
    MeanGene427
    from Napa
    A sealed AGM battery can cure that corrosion problem. I replaced the AGM in my '97 XK8 about 6 months ago, using another sealed AGM that does not require a vent hose. The battery compartment and cables in the trunk look like new, absolutely no corrosion anywhere
    ekimneirbo, Paulz and egads like this.
  7. themoose
    themoose
    Here's mine. All aluminum with the cables coming into the rear top edge of the box using rubber grommets .The top is held in place with two wing nuts with the top holding holding the box in place so when the top is removed the box can be lifted off to access and change the battery with the bottom tray staying in place.
  8. Sky Six
    Sky Six
    from Arizona
    I'm not as cl***y as the others, I guess. Battery is mounted on a tray bolted to floor with the cables going through the floor and along the frame. Back and bottom of box is cut out to cover and the top just slides for inspection.
  9. hepme
    hepme
    If you want pretty, there's plenty of them above. If you just want functionality and something that won't corrode and is made for the purpose, go to the boat section of any sporting goods or walmart store and find a boat battery holder. Most have straps for hold down and two enlarged ports for battery cable entrance. I've used many of 'em.
    R A Wrench, ekimneirbo and loudbang like this.
  10. nochop
    nochop
    from norcal
    D0F385A6-F03B-4050-A98C-011D42A4E2C0.jpeg I’ve got a funky Grand Auto plastic box. I have to keep it as it has an original Vic Hubbard sticker on it
    ekimneirbo and alanp561 like this.
  11. mgtstumpy
    mgtstumpy
    Technically my battery should be enclosed (Marine Box) and vented externally as it's a wet cell. The bolts are SS with metal tray and hold down powder coated. I run a gel cell under the front seat of my other 35 Chebby hence no venting issues. I've seen cooler / tool boxes used as covers in trunks and PU beds
  12. Just Gary
    Just Gary
    Homemade, sized for an Odyssey 680.
  13. Stainless tray and using a Deka intimidator AGM battery, I've used these batteries before with excellent results, Made in usa!! Screenshot_20221023-180413_Message+.jpg
  14. You win the prize for the coolest battery box I’ve ever seen! That is flat out awesome !!
    ekimneirbo and kabinenroller like this.
  15. I bought a cheap powder coated metal one on eBay and modified it to suit my needs.
  16. Corn Fed
    Corn Fed
    Moroso makes a simple black polypropylene box. I have one in my Coupe. The tie down bar and battery are tight inside it, but it works once you get everything situated.
  17. kabinenroller
    kabinenroller
    Thank You! The idea came to me one sleepless night, the next day I mentioned it to my friends when having lunch. One of the guys said he had the ideal box in his ba*****t on a shelf unused for years.... the rest is history.
  18. twenty8
    twenty8
    ^^^^ I'll second that...:cool:^^^^
