Technical Battery Cable Sizing?
Discussion in 'The Hokey Ass Message Board' started by 5window, Oct 2, 2025.
  1. 5window
    5window
    I am contemplating moving the battery which currently rides under the floor of my A coupe to the trunk so this 76 year old not as strong as I used to be can access it. Current access involves dropping so exhaust,tight work to free the hold downs and shifting the battery with one hand while lying on the floor. This would add about 5-6 feet of cable. What size do I need. The gas tank is in the trunk now-what safety precautions do I need? Finally, is the a way to attach the new cable to the ends of the existing cables which have battery clams on them> Thanks for the ideas
  2. Zax
    Zax
    Are you running 12 or 6 Volt?
  3. 325w
    325w
    Welding cable is your friend
    302GMC and seb fontana like this.
  4. 5window
    5window
    sorry 12 volts 350 SBC
  5. evintho
    evintho
    I'd just go with all new 1/0 ga. batt cables. Can't say enough about these guys......
    https://www.batterycablesusa.com/0-gauge-1-0-awg-extreme-battery-cable-with-ends
    Quality product, good prices and fast shipping.
    Not a problem if the batt is occupying the same trunk space as your gas tank. Pick up something like this to isolate the batt from the tank.......
    https://www.amazon.com/dp/B0CSTDNC2F/?tag=atomicindus08-20
    I put the batt in the trunk of my '54 with a batt box and ran almost 20' of positive cable all the way to my fender mounted solenoid in the engine bay. Never a problem.
    trulyvintage and seb fontana like this.
  6. squirrel
  7. This ^^^^^^^^^^^^^^ is the way to go
    Before you call them, figure out the shortest
    way to route the positive battery cable from
    where it originally went from your battery
    to the new battery location without risking
    chafing or rubbing or exposing it to heat
    or the elements, that is the length of the
    cable you will need. They probably have
    plastic wire loom to fit over the cable
    that you can purchase by the foot.
    Do not count on the frame to carry the
    negative cable to where it originated,
    install proper bonding jumpers to join
    frame components to ensure an solid
    path, buy a new cable if you are in doubt.
    Once you have engineered your design
    call them and ask their advice before
    you place your order.
    Jim
    5window likes this.
