Hot Rods Battery cutoff , any thoughts
Discussion in 'The Hokey Ass Message Board' started by Kiwi 4d, Aug 18, 2021.
  1. Kiwi 4d
    Kiwi 4d
  2. rob-redm
    rob-redm
    My 36 Ford 3w is wired with a simple on /off switch like you would see on a drag/race car. simple..
    joel likes this.
  3. Dan Hay
    Dan Hay
  4. 200 amps may prove to be a bit light. Typical V8 starter draw can be in the 200 to 300 amp range. While these will undoubtedly work for at least a while, the higher the current the shorter the contact life. These are used in electric winches, replacement relays are commonly available because of relatively high failure rates.
    Truckdoctor Andy and VANDENPLAS like this.
  5. squirrel
    says it has a 3 milliamp draw, and is suitable for cars with 2.5 liter or smaller engines. That's about 150 cubic inches.
    Looks like a solution looking for a problem?
    jaracer, slayer and 2OLD2FAST like this.
  6. Marty Strode
    Marty Strode
  7. joel
    joel
    I have the one in Dan Hays post above; it is installed on the ground cable mounted in a handy location.
    Dan Hay likes this.
  8. 49ratfink
    49ratfink
    I like the one Dan Hay posted. simple and fool proof
    Dan Hay likes this.
  9. G-son
    G-son
    from Sweden
    A cheap chinese electronic product supposed to handle several hundred amps? As much as I like a nice bonfire, it's a no from me.
  10. RmK57
    RmK57
    I take it's an anti-theft device?
  11. Kiwi 4d
    Kiwi 4d
    Good answers that why i asked. No china BBQ for me . So does the cole Hersee 24200 solenoid draw power when latched off ? Don’t think want to go out after a few weeks and find a dead battery. We don’t want to use the removable plastic key style in this build, sure they work great, but we want something more discreet.
  12. MeanGene427
    MeanGene427
    from Napa
    A CAT master switch is very simple and very HD, a D11 dozer uses one lol. The drag race ones are patterned after them, but the CAT switch has a removable key
  13. 52HardTop
    52HardTop
    It's from China! Why would you even consider it? Just put a battery shut off from a local auto parts store. It shouldn't be hard to find one.
  14. -Brent-
    -Brent-
    Got a link or part number?
  15. Jokester
    Jokester
    Does the battery in the remote control have its own cutoff? Just curious.
    .bjb
  16. MeanGene427
    MeanGene427
    from Napa
    Cat 7N0718 is the original, there are lots of aftermarket replacements on Amazon
  17. jaracer
    jaracer
    This is what we used for heavy trucks.
  18. gimpyshotrods
    gimpyshotrods
    Imperial Amps, or Metric Amps?
  19. Mimilan
    Mimilan
    For the H/D circuit ,mount a Ford starter solenoid at the battery and run a starter switch wire to it.
    That way the circuit is as dead as a dodo unless cranking.
    The rest of the circuitry can usually handled by a 40a isolator switch
    This is how we did it on our race car.
  20. I like this one, too.
    The previous owner of my Chevy AD truck eliminated all the door locks but at least he put a cutoff in. The Advance Design trucks locate the battery under the p***enger side floorboard so the cutoff is right there under the seat, flush with the floor. You want the detachable key/handle like the one above so you can carry it in your pocket while the vehicle is parked. Box or shield it and consider anti-tamper screws to discourage hacking and theft.
    clem likes this.
  21. Hollywood-East
    Hollywood-East
    mgtstumpy and Mimilan like this.
  22. chop&drop
    chop&drop
    I have a battery disconnect latching relay like used in motor homes in my roadster and am putting one in the coupe I’m building. Easy to install, activated by a momentary push****on switch that can be hidden anywhere. No draw in either position.
  23. - Don't laugh, but I have been involved with load testing some of this chinese electrical ****, and their rating is nowhere near what is claimed . Things like solid state relays (SSR'S) have a spec rating of say 50 amps, but the main component can only handle 25 amps, and it has the part number stamped on it, stating it's rating! I had a bunch of these fail at 80% rated load, and couldn't figure out why until I broke the potting out and investigated it.
    So 100 Chinese amps = 50 imperial amps as a general rule if you are stuck with buying this junk.
  24. Are metric amps the same as British amps?
    427 sleeper likes this.
  25. gimpyshotrods
    gimpyshotrods
    No. Those are British Standard Whitworth Amps.
    Those tend to leak out.
  26. Mimilan
    Mimilan
    Wrong..............Those are Lucas amps
  27. gimpyshotrods
    gimpyshotrods
    Lucas is just one brand name on British Amps.
    Truckdoctor Andy likes this.
  28. Mimilan
    Mimilan
    No ,they are different.
    For some reason only Lucas amps cause an exothermic reaction.:D
    Whereas normal British Amps [Smiths etc] seem OK
  29. Lil32
    Lil32
    I use this style coupe.
    placed under dash
  30. old chevy
    old chevy
    That is what I use. Very few people have the specific key for them. Works great.
