Hot Rods Battery fuse
Discussion in 'The Hokey Ass Message Board' started by Kevin Ardinger, Jan 12, 2020.
  1. Mimilan
    Mimilan
    The sustained rating is for a "slow blow" fuse which can take a momentary spike above the 20 amp.
    The 150 amp rating is the absolute safety limit for a spike then it blows.
    Slow blow fuses are very common in Audio. They are coiled like a filament in a light bulb.
    They are normally rated like 17/35 or in your case 20/150
    Here's a slow blow fuse
    Vs a normal fast acting fuse
    It's a "Lucas" necessity :D
    rusty valley and Boneyard51 like this.
  2. Boneyard51
    Boneyard51
    I don’t think I’ve ever seen a slow blow fuse rated for 20 amps and 150 amps. Maybe 20 amps and 35 amps. But I don’t think 20 will reach 150.
    Also I went and looked at the Mr. Gasket battery switches and they are rated at 20 amps continuous and 125 intermittent. I think that’s what he is talking about. ......maybe.
    Bones
  3. Kevin Ardinger
    Kevin Ardinger
    Pretty sure the directions used the term fused. I thought it was odd too. I'll double check the paperwork.
    Thanks for all the input
    Boneyard51 likes this.
  4. donno
    donno
    Fuse's "blow". Fuseable links melt.
  5. Boneyard51
    Boneyard51
    Well actually they both “ melt” that’s how they both protect the circuit, when the resistance gets too great and raises the temperature to the melting point of the fuse material. The main difference is usually the “ fuses” are in a protective case of some sort, gl***, plastic, etc. The fuseable link usually just has its insulation, similar to wire insulation, for protection, and sometimes that isn’t enough!
    Bones
    Mimilan likes this.
  6. garyf
    garyf
    Fuesable links cause fires when they are wired ,wrapped into a wiring harness or laying on something that will burn.. When they blow or melt if wrapped in a harness they will ignite the plastic or cloth coating on the harness and create more shorts. A fuse link when used correctly is wired out and away from any other wires so it burns off or blows and stops power flow to its circut.
  7. Kevin Ardinger
    Kevin Ardinger
    You are correct. I looked at the instructions again and it does say rated. Not sure how I came up with the fused terminology. Dementia setting possibly.
