Technical Battery Gimmick
Discussion in 'The Hokey Ass Message Board' started by verde742, Oct 10, 2016.
  1. verde742
    verde742
    Without listening to a long commercial to buy a $49.00 book, Anybody know the 'gimmick' for never buying a battery again.
    The ad on the "box" says a man taught him how in 10 minutes, now the two of them want $49.00 for the "book" of knowledge.
    Just wondering.
    31Vicky with a hemi likes this.
  2. saltflats
    saltflats
    from Missouri
    I see that also and had the same thought.
    Probably put an aspirin in the cells.
  3. FrozenMerc
    FrozenMerc
    loudbang and KoolKat-57 like this.
  4. pat59
    pat59
    The gimmick is, when your battery goes dead, you just buy a new car with the profits that you made from selling the stupid battery book. :)
  5. upspirate
    upspirate
    Ride a bike
    jeffd1988 likes this.
  6. There ain't no free lunch.
  7. Hnstray
    Hnstray
    from Quincy, IL
    I doubt it has anything to do with preservation of your battery, but more likely a way to keep getting replacements under warranty. However, even that is doubtful, since typically only the balance of the original warranty applies to replacement batteries.
    Save your 49.99.......that will cover at least half of the next new battery you buy. Buy the book and you'll still be buying a new battery in due time.
    Ray
    bobg1951chevy and Stu D Baker like this.
  8. wraymen
    wraymen
    The book is an easy score. Its the decoder ring that makes it all readable. Send me 19.95 plus shipping, sorry no personal checks or COD accepted.
  9. Where do I send the cash?
  10. gimpyshotrods
    gimpyshotrods
    They are not called the Friendly Suggestions of Physics.
    They are the Laws of Physics.
  11. Yeah !!! What he said
    Serious question that has nothing to do with batteries -
    in all of your engineering education and adventures have you had to plan or adjust or calculate a project with respect for the earths curvature?
  12. Rusty O'Toole
    Rusty O'Toole
    There are plenty of web sites and videos on reviving batteries. Most times they are sulfated. A special charger using alternating current is supposed to break down the sulfation. You can buy a charger or make one. Have also heard of using certain chemicals to add to or replace the acid.
    If you have some old batteries laying around why not experiment? What have you got to lose?
  13. gimpyshotrods
    gimpyshotrods
    Only when working with rockets.
    Dino64 and 31Vicky with a hemi like this.
  14. Rusty O'Toole
    Rusty O'Toole
    A surveyor friend told me there are basically 2 theories of surveying
    1) the earth is flat
    2) the earth is round
    The first theory is easier and good enough for surveying house lots. The second is harder but must be used for surveying roads and large areas of land because it takes account of the curvature of the earth.
    He told me this 40 years ago, I expect by now there are computer programs that do the hard math for you.
    clem and 31Vicky with a hemi like this.
  15. GPS and a calculator. Used to be logarithm tables and a slide rule. :D
    Civil designers still use equations, sometimes they plug them into a spreadsheet but everything still has to be calculated.
    As for the battery, I used to know an old guy that sold used batteries, if the plates hadn't shook loose he flushed them and filled them with fresh acid.
  16. squirrel
    I paid 48.88 plus tax for the last car battery I bought. I got a better deal.
  17. verde742
    verde742
    where, when, what brand, size group?
  18. squirrel
    wal mart, the cheap ones, several sizes are that price. I got a 24.
  19. When I Lived in Tuscon, AZ there was a Guy that Sold
    Rebuilt Batt.
    he Made a Lot of Money
    he use to cut the Top off & clean them out Check the
    plates & recharge Them
    just my 3.5 cents
    or when the Cows
    home!
  20. dreracecar
    dreracecar
    from so-cal
    Jimmy bar, some wrenches, and a black ski mask
    $49.99??? whos the thief here
  21. 19Eddy30
    19Eddy30
    from VA
    Hand crank & magneto
    Or manual & magneto!!!
    :D
  22. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    Don't know if this counts but I always rank and support my firewood in such a way that the centrifugal force of the earths rotation doesn't make it fall over.
  23. verde742
    verde742
    yep that helps :rolleyes:
  24. blackanblue
    blackanblue
    So I,m in Ontario should I stack north to south or east to west.
  25. X38
    X38
    I would have thought that parallel to the equator would be more stable. Also, check with astronomers or cosmologists because the tilt of the earth's axis varies over time. You may have to dial in or out a few degrees.
    Kroombit and Zerk like this.
  26. Bad Eye Bill
    Bad Eye Bill
    from NB Canada
    Exactly!.
  27. 56don
    56don
    The only difference in the cheap ones and the more expensive ones is that you get a longer warranty with the more expensive one. You don't get a better battery, the money goes toward the warranty.
    Truck64 likes this.
  28. jeffd1988
    jeffd1988
    Man never buy another (battery) Catalog? Waste of money for that i would think. All it gona say is replace the acid or distilled water and leave it upside down for some time and then slow charge the thing. Idk im just talking but i did youtube some bs and i dont believe none of it. Just get the el cheapo from walmart and see if autozone will give you core store credit to buy a soda.
  29. That's not entirely true, probably true for some cheaper brands but not all. You're paying for plate size/area, with 'better' batteries having larger plates. Bigger plates, more current available. As batteries age, sulfation reduces area and performance drops off. One issue with larger plates is when the battery does sulfate, the sulfate drops to the bottom of the cell and shorts them out. Bigger plates extend down into the cell further, so they will fail 'faster' as distance from the bottom of the cell to the plates is smaller.
    tb33anda3rd likes this.
  30. squirrel
    I agree with Steve, you do get a better battery if you spend more (usually). But the increase in price, is not proportional to the increase in battery life. Pay twice as much, it'll last 30% longer.
    gas & guns likes this.
