Projects Battery Hold Down?
Discussion in 'The Hokey Ass Message Board' started by Jake Sippl, Nov 30, 2015.
  1. gnichols
    gnichols
    from Tampa, FL
    I do like the trays that have the top strap across the center / over the short width of the battery, far away from the terminals. In the lessons learned department, I had one of those Summit / Moroso style plastic boxes with lid (6 fasteners as I recall) on my 37 Fordor. Very cool, well made, looks nice, race legal.... but I over-engineered / out-thunk myself and put it in the trunk up over the rear axle on the right side. Wasn't I racy? Lots of extra cost in the long leads forward, too. Dubble duh. Ran the vent lines, etc. On the only day I ever needed a jump I was on a trip... and had to completely unload the trunk (at least it wasn't raining) and use a screwdriver to remove those nifty looking screws. Just a pain. Nothing easy or "quick" about getting to the battery when I had to. Next time the box will have a strap or something easy to hold the lid on (back to marine box types) and I'll put the battery in a location far easier to access, preferably under the hood like Henry did it in the first place. Certainly not on the frame in a place you'd have to crawl under the car or use a lift to service the battery. If not, I'll add some jumper terminals / plug set in a convenient place reasonably close to the battery. Gary
  2. stimpy
    stimpy
    for tight spot batterys I always make a jumping connection near it or near the line end in the front close to the starter , one thing I learned from working on trucks is to write the date of the battery on the box so you know if its dead from draw or dead from age . my buds battery box to get at it you have to unbolt it from under the car then slide it out as its that tight of fit , but he wanted a clean trunk in a O/T , and we only have had to remove it 2 times and that was to change it out ( dead from age ) I am trying to decide what to do on the 50 as I have lots of room in the engine compartment but looking at weight bias too .
  3. mrspeedyt
    mrspeedyt
    i have a bungie cord on it... try just super glue on it...
    right now I'm trying a $20 garden tractor battery in my 89 suburban (which starts quickly)... seems to be working good so far. if not super glue then maybe I'll try some silicon bathtub seal stuff.
  4. Jake Sippl
    Jake Sippl
    from Detroit MI
    ***uming you're talking about me, I appreciate this informative post you made on helping me with this issue. I made this thread to see what other people did because I was curious, not stupid. But thanks for making me aware that I have no common sense! What a pal. :D
