Technical Battery in trunk what to do with it !
Discussion in 'The Hokey Ass Message Board' started by Jeff J, Oct 2, 2014.
  1. Jeff J
    Jeff J
    So , I was finishing up the trunk in my 32 Ford and was trying to figure a way to hide the battery . As when we travel really don't want stuff laying on the battery ! Really didn't want one of those plastic roadster 32 005.JPG roadster 32 010.JPG roadster 32 011.JPG roadster 32 013.JPG roadster 32 018.JPG battery boxes . So this is what I came up with ! Show me your idea what you did on your ride !!!!
    I had some metal laying around and thought this would be a good time to roll some flames ,this time going to do them in reverse in stead of raised ! So I did a little painting on it to !
    i.rant likes this.
  2. I know a lot of people will disagree but I never make the battery box out of steel. Use wood or fibergl***, something that won't short out if it comes in contact. That's why 99% of aftermarket boxes are plastic. Make it look like a cooler or a tool box, I even saw one that used a small flip top cooler.
  3. HOTFR8
    HOTFR8
    You could always put a plastic battery box inside a metal box so it looks like something else.
  4. Jeff J
    Jeff J
    Sorry forgot to add ,It has over 2 " of clearance. I used side posts and have plastic covers on terminals so there no way of shorting out ! Ty
  5. beachbum jim
    beachbum jim
    from Loris, SC
    WP_20140822_002.jpg This is what I came up with for fellow HAMB member sctattooer. The box is made out of 1/2" PVC board.
    NICKEYCHEVY60 likes this.
  6. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Plastic battery box inside a tool box. If you find one a little bit wider than you need, you can put tools in there too.
  7. Vintage Pipe
    Vintage Pipe
    from Greer, SC.
    Used a boat battery box bolted to the truck floor with a vinyl cover. IMG_2849.JPG
  8. Buckster
    Buckster
    What about ventilation for the fumes?
  9. 39ChevyBob
    39ChevyBob
    Vintage train case, vented underneath - using a Gel Battery.
    NICKEYCHEVY60 and lothiandon1940 like this.
  10. southerncad
    southerncad
    Yeah, what Buckster said....how do you vent a cooler or toolbox?
  11. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Sealed top, hole through the bottom with a tube if needed. Not overly complicated.
  12. AZbent
    AZbent
    On the planes that I have moved the battery on, the battery goes in an aluminum box with wood on the sides to prevent shorting out. The battery is vented with a small tube going out of the fuselage. No problems, works great.
    Mark
