check with eric at riley automotive "vaphead" he sells a batwing but im not sure if it has the spring mount or not good luck Zach
Contact TOTAL PERFORMANCE at 203-265-7107 for technical questions. They may have it in stock or can help you find one. Bob
Me, too. I think he means the next set of mounting holes in the axle where the spring perches normally fit -- not sure what they're called, though. Spring perch mounting holes? ;-) Pretty cool product from TP, though. For ninety four bucks it's kind of hard to justify fabbing your own.
Here's an alternative. $71.00 http://www.welderseries.com/catalog/product_info.php?products_id=326 You can also buy just indvidual pieces. 28903 $7.50 28905 $9.00 10036 $9.50 Hope this helps.
Sorry, not kingpin... I meant as opposed to weld-on. I want to mount it where the bones go. the ones posted are what I was talking about. Thanks
