BBC Crane roller cam ID
Discussion in 'The Hokey Ass Message Board' started by mongo4u2, Apr 20, 2009.
  1. mongo4u2
    mongo4u2
    from sparta
    Hi Boys,
    I got a crane roller BBC part no. 139536 ,trying to get the settings and specs. Crane is out of biz, by a couple my old books it's late 80's early 90's because my circle track no.s are close , any body got a crane cat around then , Thanks Dave
  2. fridaynitedrags
    fridaynitedrags
    If you have a block, crank, timing set and lifter, you can check the specs yourself with a degree wheel and dial indicator. Start with the lash at 0.025", tighten or loosen from there.
  3. Rogers Performance
    Rogers Performance
    I looked in all my crane books i go back to 76 i can't find that number.
  4. fridaynitedrags
    fridaynitedrags
    Could be a custom grind that won't show in a catalog.
  5. Rogers Performance
    Rogers Performance
    Then it would have the lobe ID,s etched in the cam
    something like R-274/280
    I have a Crane Cam Master lobe list catalog if it has the etchings it may or may not have them as there is no date on this.
