Technical BBC Hammering & Squeaking
Discussion in 'The Hokey Ass Message Board' started by GearheadsQCE, Jun 3, 2021.
  1. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    This is almost embar***ing. My shop truck has a 454 that suddenly developed a hammering sound with an attending squeak. It is scary loud but not like a rod knock. It seems to be coming from the front of the engine. Drivers side may be slightly louder, but I'm old with poor hearing.
    Here is what I have done so far:
    Removed the alternator and AC belts to eliminate the water pump. No Change
    Checked the timing with a light to see if chain might be loose. The timing is at 8 degrees no vacuum advance. Revving the engine a bit, it advances a few degrees. Letting it snap back to idle, the timing returns exactly to 8. No evidence of chain whip.
    Listened with a tube to timing cover, fuel pump, intake manifold, valve covers, oil pan etc. Nothing sticks out as being the source.
    Checked oil pan for dents. Nothing there.
    Oil pressure is @ 30 psi.
    I attempted to post a video, but it didn't work. any tips on doing that?
    This has me stumped, I have never heard anything quite like this before. It just started out of nowhere. The truck doesn't get driven a lot, but it always starts and runs great.
  2. Blues4U
    Blues4U
    from So Cal
    Harmonic balancer loose?
    VANDENPLAS, ClayMart and tractorguy like this.
  3. Doublepumper
    Doublepumper
    from OR-WA, USA
    Clutch/transmission area...flexplate cracked...something in the clutch/broken clutch finger...bolt backed out and rubbing...?
    tractorguy and squirrel like this.
  4. Wrench97
    Wrench97
    What year is the engine?
    The ones with roller rockers were known to squeak if a push rod bent or the roller started to fail.
    Hollywood-East and squirrel like this.
  5. Kevin Ardinger
    Kevin Ardinger
    Hammering and squeaking sure sounds like a rod bearing. Oil pressure can still be good as the bearing is probably smeared in the oil p***age.
  6. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Thanx guys,
    I'll check all the things mentioned.
    The noise does increase in frequency with rpm but not steady like you would normally hear from a rod. It does seem like it's coming from the front.
    I haven't checked flex plate yet. But it does sound like that.
    The engine is an '86 so no rollers.
    Wouldn't the harmonic balancer show up somehow with the timing light test?
    A video would be helpful, I'm working on that!
  7. RMR&C
    RMR&C
    from NW Montana
    Does it have power steering? I recently had a GM PS pump pulley come loose....made some ominous noises till I found it.
    tractorguy likes this.
  8. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    It does have PS. Can't hear anything in that vicinity and the power steering works fine.
    Will pull that belt off too and check
    RMR&C likes this.
  9. tractorguy
    tractorguy
    Squeak.......squeal is often a sign of a failed and/or spun main bearing. Squeak is dry bearing shell turning in block. pressure is good because debris from back of main bearing shell has plugged oil p***age in block so no big oil loss. On a slightly less ominous note...... galled or scored valve stems will give a similar noise.......possibly caused by overheating
    scotty t likes this.
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    This isn't the greatest, but I can do a better one if that would help!
  11. jaracer
    jaracer
    If a bearing spins in a rod, it can block off the oil hole. That rod won't get any lube, but the oil pressure will be okay. Do you have any vibration along with the noise? If it does it with all the belts off, I'd check the back end flywheel/flex plate like others have suggested. If that's all good the pan is the next thing that needs to come off.
    milwscruffy likes this.
  12. jaracer
    jaracer
    It would be nice to hear it rev and come back down. A rod knock is normally worse off load; when it coasts back down from a rev up.
  13. samurai mike
    samurai mike
    water pump?
    SR100 and Blues4U like this.
  14. seb fontana
    seb fontana
    from ct
    Muffler bearing.. :D..Couldn't resist. Does it alter in gear?
    VANDENPLAS likes this.
  15. Black Panther
    Black Panther
    from SoCal
    That sounds ugly....is the dust shield between the trans and the engine bashed in? I had an engine make weird noises like that, that purred like a kitten once I removed the shield.
    RMR&C likes this.
  16. greybeard360
    greybeard360
    Sounds like an intermittent double knock. Squeal sound like an old belt chirping.
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I'll get back on it tomorrow. Lots to check out.
  18. Blues4U
    Blues4U
    from So Cal
    This is a good one to use a hose as a listening device to narrow down the source of the noise. One end of the hose to your ear, and the other end around various parts of the engine/accessories. I'd pull the belts off and start it and see if the noise is still there with no belts on it.
  19. Engine stethoscope,,,,,,cost only a few dollars,,,,,,you can safely diagnose any noise in an engine .
    They work !
    Tommy
  20. 270ci
    270ci
    You can also pull plug wires one at a time while it's running/knocking to find out if your issue is ***ociated with a particular cylinder.
  21. X-cpe
    X-cpe
    A double knock usually indicates a piggy backed rod bearing allowing the piston to hit the head. (Not in Naval vernacular) 270ci has the right idea as far as locating or eliminating cylinders.
  22. sdluck
    sdluck
    Flex plate broken
  23. SS327
    SS327
    It sounds ugly. I did have a #1 main spin on a 454 and broke a crank or visa versa. It sounded just like that.
  24. Onemansjunk
    Onemansjunk
    from Modesto,CA
    I had a fuel pump rod make all kinds of weird noises on a 454 . I pulled the fuel pump and the plug to find the rod binding up and it took pliers to pull the S.O.B out. I ran it over some 400 grit sandpaper, oiled it up and re***embled. Noise went away. Strange I know. I think being gummed up it wasn’t returning fast enough and the cam eccentric was banging up against it ??
    tractorguy and VANDENPLAS like this.
  25. I’ve seen belts causes noises like this
    Damaged power steering pump
    Bad balancers
    Timing chains
    the chain is usually more “ rattely” the a knock .
    also torque converter/ flex plate bolts
    ****** inspection covers can sound like the world is coming to an end is they get bent a bit.
    Other then that it could be internal , usually rod knock or main knock is rpm driven.
    balancers that sepperate can make noise even after shut down is the rubber is really torn apart.
    I had one years ago that sound like a super charger winding down when I shut the engine off , told people I had the mad max blower on my car and “forgot to disconnect it “ on shut down :p
    SR100 likes this.
