Technical BBC high idle after thermostat opens?
Discussion in 'The Hokey Ass Message Board' started by 1951mercury, May 31, 2019.
  1. 1951mercury
    1951mercury
    from Illinois
    Alright so weird scenario is happening...402 bbc, no choke, holley 4 barrel carb, new 180 degree thermostat. When the engine warms and thermostat seems to open the idle goes up from around 700 RPM to about 1100-1200 RPM. It will not go back down either.
    Any ideas on what is causing it or how to fix it?
  2. Jethro
    Jethro
    Vacuum leak when hot? Try tightening the carb baseplate and float bowls , maybe even the intake manifold bolts.
  3. mark latham
    mark latham
    Is the throttle return spring pulling the throttle all the way back closed?
