BBC timing
Discussion in 'The Hokey Ass Message Board' started by Kubbee47, Jun 30, 2010.
  1. Kubbee47
    Kubbee47
    from minnesota
    OK motor heads. The BBC in the 48 seems to run best at 22 degrees initial and 41 degrees total. The cam has a 244 duration @50 and is a hyd. roller with 560 lift. with a dual quad
    Seems like a lot of initial, but if I back off it stumbles on standing wot. No pinging or heating isses, just runs graet at this timing.
    Any thoughts if this is an issue?
    Gary
  2. Initial sounds a little high, but a BBC expert that helped me build my 480 told me that they like around 38 total, so you're not that far off. Maybe try grinding the stops a bit on the rotor weights to get more centrifugal advance so you can back the initial off a bit.
    Guess if it will start at 22, no harm no foul..
  3. CONNMAN
    CONNMAN
    from Lampe,Mo.
    Ran my old BB's at 42 degrees total ,18 degrees initial with the distributor set a 24 degrees coming in at 3000 rpm ,,if yours starts and runs good as it is ,,,leave it alone and run it ,,
  4. Glen
    Glen
    I ran 20 initial and total 38 in mine, 40 is fine if it doesn't ping
  5. Black_Sheep
    Black_Sheep
    I run 20 initial and 38 total in my 292/.509 cammed 440 with no ill effects.
    If your Chevy runs good then go with it...
