Bead Roller RPM?
Discussion in 'The Hokey Ass Message Board' started by Three Widow's Garage, Nov 18, 2011.
  1. Three Widow's Garage
    I Just found a gear reduction motor 1/2 hp, 30 rpm, reversable, I'm going to mount it on a Woodward Fab bead roller and have trying to determin what a good final drive RPM would be? I searched all the threads and it looks like its been done quite a few times, but couldn't find where anyone
    mentioned a good final drive ratio. The motor is A/C 110v so not to easy to make it a variable speed. Thanks for any info, JJ
  2. heatnbeat
    heatnbeat
    from Madera,Ca.
    Hi JJ
    here is a picture of mine. it has a 98:1 gear ratio 3 phase motor.About 17 RPM I use a VFD and run it about 10 RPM alot more controlable
  3. Blue One
    Blue One
    from Alberta
    I have a Dayton gear motor for mine. 1787-1 ratio.
    I am copying a few other guys who have used this motor and they work awesomly well. With 2.8 RPM they are very easy to control and intricate work is easier.
    DAYTON GEARMMOTOR
    Model 2Z797B
    F/L Torque 450 in lbs
    RPM 2.8
    Ratio 1787:1
    Volts 115
    Amp 1.3
    HP 1/15
    SF 1.0
    A/C
    Right angle gear motor
  4. Jim Stabe
    Jim Stabe
    If you get it running too slow I find that I tend to wander on long straight lines. For me the best of all worlds would be a foot pedal speed control that would go from about 3 rpm to 15 rpm - I haven't found that solution yet.
  5. carlitos way
    carlitos way
    anyone have some pics of one?
  6. Three Widow's Garage
    Thanks for the replys. I have it figured to use a chevy flexplate for a the driven gear, just trying to work out what size gear to get for the motor. The sizes that are avaible would give
    either 7.7 rpm or 10.5. The dies are 2" dia. at 10 rpm would net about 60" of feed a minute,
    thinking that would be a good starting point. It will be set up with a disconect so you can use manual feed as well if you need to go slower. I'll try to post some pics when i get it all done.
