Bead Rollers
Discussion in 'The Hokey Ass Message Board' started by ascenttm, Feb 28, 2008.
  1. ascenttm
    ascenttm
    from HERE
    I've seen a few posts here about HF bead rollers and how to strengthen them up because they flex. Are the plates too thin?
    I have a roller from Woodward fab that cost less then the HF roller, is the same design but seems to be better built, has grease fittings on the blocks and works well, the plates are ½ inch and don’t flex Granted you’ll still have to make a stand.
    Here's a great tech on a HF roller
    http://www.jalopyjournal.com/forum/showthread.php?t=137858
    Check out the two rollers.
    http://search.harborfreight.com/cpisearch/web/search.do?keyword=METAL+FABRICATION+KIT+&Submit=Go
    http://www.woodward-fab.com/woodward_fab_bead_rollers.htm
  2. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I dont know...is this thread asking something? Or telling us something?
  3. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    My HF one is fine, sturdied it up w/ 2x2. Seems to work OK except for user error. :)
  4. Redneck Smooth
    Redneck Smooth
    from Cincinnati
  5. lehr
    lehr
    Any beadroller made like that will flex.. Tighten your dies together and look from the crank end towards the die end and roll it over you will see it flex from side to side. Pat
  6. bdierks
    bdierks
    the HF rollers are made from 3/8 inch plate
  7. pimpin paint
    pimpin paint
    from so cal
    Hey,
    It's doubtful that one will handle anything over the rated 20 gauge
    rating, given the size material it's made from. If it does so, it's a
    question of how long before it won't!
    I've seen some masterful "hot rodding" done to make a bead roller
    from the Chi-Com. built ones, but unless you can turn your own
    dies, you're limited by what's available, the dia. of the roller shafts,
    and the set screws that hold the dies to their shafts. Always keep
    in mind, these are all made from s**** steel, from what use to be
    Subaru, Datsun and maybe an old Norge washer or two.
    S****ey Devils C.C.
    "Meanwhile, back aboard The Tainted Pork"
  8. rodknocker
    rodknocker
    All I know is, whatever bead roller Kiwi Kev has WORKS!
  9. DIRTYT
    DIRTYT
    from Warren,MI
    i got a h.f. one we did my buddys floors in my his 50 chevy with it. it flexed and came out decent but for the price who can complain. you get what you pay for.
  10. my hf was a piece of junk till i made a backer out of 2" tw square tubing, now it is as good as the hi dollar ones, at a fraction of the cost.
