1952-59 Ford bear claws
Discussion in 'Off Topic Hot Rods & Customs' started by bulletproof1, Aug 14, 2009.
  1. bulletproof1
    bulletproof1
    from tulsa okla
    anyone ever install bear claw latchs in 52-54 fords .if so what kit did you use?
  2. phqnflt
    phqnflt
    from NOR CAL
    I'm interested to I have a set already. Does anyone have pics installed?
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    You might check the archives for"Two Guys Garage" about 3-4 months ago they covered a complete install around that time.
  4. genosslk
    genosslk
    I have installed about a half dozen sets of the latches in various cars, all pre-war cars and not yet my '53. In all cases it required fabrication to the door pillar and door with opening mechanics to overcome. You can either place the pin in the door or pillar depending on how you want to the 'claw' to open with electrics or mechanics. I have not found a reason to change the '53 yet from stock. There are many web sites that show various installations with the 'claw' if you have the time to research for them. Good luck.
  5. missysdad1
    missysdad1
    Hey, Geno! For those of us who have much greater skills with a torch than with a computer, would you be willing to share a couple of the websites which show well-done installations. I know how to search...but just barely. Thanks in advance. Eric
  6. genosslk
    genosslk
    Thanks Eric.... I'll spend a bit of time on Monday morning to look up a few for you guys.
  7. genosslk
    genosslk
    Ok guys, I did my homework a bit early so you can get started installing those bear claws this weekend!
    What I did to get installation guides is simply type in "Bear claw door latch installation" on google. Several sites showed up! Click on the ones you want. Many magazine articles. I was going to list the sites but I want to eat and relax tonight rather than type for the next few hours!
    Geno
  8. bulletproof1
    bulletproof1
    from tulsa okla
    what about brands or supplier? i can handle the install
  9. missysdad1
    missysdad1
    Hagen. Run the search Geno suggested. It works. Thanks, Geno, for doing the footwork!
    Eric
  10. genosslk
    genosslk
    I've bought a bunch of these bear claws from several vendors and they all seem to be the same quality. Maybe one outfit builds them all. I haven't had a problem with any of them.
