Hi. I wonder if anyone have the SKF bearing numbers for all the bearing to a Halibrand 201? Are you guys running a sealed bearing at the lower shaft on the torque tubes side?
Ok here are the bearing numbers and sizes in mm 6306 x 1. 30x72x19. Front lower shaft 6206 x 1. 30x62x16. Rear lower shaft 6304 x 2. 20x52x15. Rear cover 6205 x 1. 25x52x15. Pinion support 6307 x 2. 35x80x21. Pinion bearings to suit Getz gears ( not Ford) Get all bearings with a C3 clearance, as Quickchanges will typically run around 55-75 deg C on the street.
