Hot Rods Beating a dead horse- how to choose a cam manufacturer for SBC
Discussion in 'The Hokey Ass Message Board' started by Chris, Apr 17, 2017.
  1. R Pope
    R Pope
    I ran a few "151" cams in 283's and 350's. Ridiculous RPM potential and nice lopey idle. Been quite a while, but I think the full number was 3836151, supposedly the hottest juice lifter cam GM made for the SBC. A guy in Prince Rupert sold 'em for about $69 back in the day.
  2. Gman0046
    Gman0046
    In my 327 very happy with Comp Cam 262 H and valve springs.
    olscrounger likes this.
  3. olscrounger
    olscrounger
    I've had great luck with Crane,Elgin and Sig Erson cams. For a couple of mild 327's I used a Crane that has 266 duration 440 lift(don't know the number)-Cam Dynamics used to grind this one as well. Elgin makes copies of the 097 and 151 cam that work well too. Years ago when our 55 was our main car, I changed cams quite a few times(5) to see the difference,etc. All were run at the drags some too. The best the car ran at the drags and as a daily driver was a Sig split duration TQ20 intake profile and TQ30 exhaust profile-have the card somewhere.
  4. greybeard360
    greybeard360
    I have had a lot of luck with Lunatic VooDoo cams. Real torque monsters and not a jack in the box idle if you choose the right one.
    Sent from my Moto G Play using The H.A.M.B. mobile app
    bobss396 and olscrounger like this.
  5. Montana1
    Montana1
  6. MAD 034
    MAD 034
    from Washington
    Just a friendly reminder that too large a cam and not enough compression in a small cubic inch engine is not much fun.
    Atwater Mike and olscrounger like this.
  7. Rocky
    Rocky
    Classified Editor
    I use to run the 350 HP 327 cams for the street...loved 'em!
  8. Montana1
    Montana1
    Also, a mild cam for a 350 will have a noticeably rougher idle in a 283, because of the displacement difference.
  9. southcross2631
    southcross2631
    I like the NHRA stock eliminator cams. for a stick shift. .390-.410 around 280 duration . Sound really good and gobs of torque and top end pull. Isky or Howards.
  10. studebaker46
    studebaker46
    I have commented on this in another I just like the humor of Chris thinking outside the blue oval and the flathead. on a serious note this sounds like a fun build good luck Tom
  11. I'm also a Crane Cams guy, haven't always had the best of luck with Comp. Cams, but that bad luck was with big blocks, and they were a little notorious for eating cams back in the day. Didn't have a problem with Crane, so I'm still running them. Another manufacturer no one mentioned that's been around a long time (and is local down here) is Schneider Cams. Haven't tried them personally, but I know several people who have. Sponsors a lot of local shows with free cams as raffle prizes as well. He and Crower are both local, so I may give one of them a try on the next build (looks like that's going to be a 455 Olds, at this point).
  12. dreracecar
    dreracecar
    from so-cal
    I have lunch with Isky everyday,
    Rod has been their only tech/sales guy for 20 years, and will have the answers.
  13. buffaloracer
    buffaloracer
    from kansas
    What I want next was a cam for the 302 that was billed as an off road service came by GM. I don't remember the number but it is a healthy SOB. :D
    Ran the off road 140 cam years ago in a 292 Chevrolet with 11.5 to 1 trw pistons years ago. Solid lifter cam.
    Might be what you are looking for.
  14. I still do. They are a good all around cam for a streeter.
    I have a line on an M/T 30/30 cam that I am thinking about using. I cannot find specs on it but knowing Mr Thompson it should be like a duntov on steroids. LOL
    @greybeard360 Lunati used to make a cam that they called a throttle stop cam, maybe they still do. it was designed specifically for bracket race cars and the idea was that the control box could shut your throttle down then get right back on it and the cam would perform flawlessly. We decided to try one in a big inch chebby because it should work well in stop and go traffic. it did work flawlessly and we used them in several builds.
    Could be. It would be going in an 11.5:1 355. PAW actually had a sale on them back in the '90s and intelligent man that I am I managed to not buy a couple.
  15. vinfab
    vinfab
    42 comments and no one has mentioned that 55 to 57 small blocks (along with 348/409 and 65/66 big blocks) take a grooved rear cam journal. Failure to use one, will cause valve train failure due to lack of oiling. Pick a cam manufacturer and call them. Most will grind the rear journal for minimal cost or even no charge.
  16. Old-Soul
    Old-Soul
    I guess I just ***umed he knew that and had it in the works to get his cam cut for oiling.
  17. Chris
    Chris
    Would the cam I mentioned be considered "too large" with around 9-9.5:1 compression? This is not really that big of a cam...
  18. bowie
    bowie
    Chris: The old 300 horse cam, was a fairly mild grid ; works fine in a mild 283". I too like the L79 ,350 hp cam; have had one in my '32 , 283 ,.040 over 10.5 comp for many years.
  19. henryj1951
    henryj1951
    from USA
  20. The 300 horse cam will work fine with a 9:1 compression motor. Hell the L79 cam works fine at that compression.
    bowie and Chris like this.
  21. Chris
    Chris
    If this was a flathead I'd know exactly what I'd want to do lol! The problem is, there is so much info and so many choices for Chevs...it's hard to know where to start. I've been building this car in my head for a long time. My build also has a certain cryteria... I DONT want a huge earth pounding, mean and nasty small block. I DONT want a high compression engine with a radical cam that is a bear to drive in traffic and such. I want a decent sounding, broad power engine that will perform well in a car with a less then optimal trans and rear end. No high RPM clutch dumps or anything. Lots of guys have steered me towards the factory 300 HP cam, so that was my starting point.
    I really just want to experience a set up like a guy in the early 60's would have with his old Ford.
    1Nimrod, hotrodharry2 and brad2v like this.
  22. Until you find your way into the factory race stuff the GM cam profiles all pretty much have a broad torque band. I think you will be real comfortable with your cam choice.
    I don't remember the exact numbers but if you run that cam straight up it should pull real well off idle to about 5K. Good steady pull nothing that is going to surprise you when you hit a magic number.
    Atwater Mike likes this.
  23. henryj1951
    henryj1951
    from USA
    Short GUIDE ---- good read----
    Under 200 degrees hydraulic: Smooth idle, good fuel economy. Use with a stock or low-cfm carb and stock or small-diameter tube headers. Can recurve distributor or use aftermarket ignition. Retain stock rear gear ratio.
    200 to 220 degrees hydraulic, under 230 degrees mechanical: Good idle, low-rpm torque. Good for towing, RV, and off-road use. Works well with low-cfm carb, torque-producing manifold, aftermarket ignition, and headers. Good in cars up to 4,000 pounds and moderate-sized engines. Stock or mild gear changes are OK if not too high.
    215 to 230 degrees hydraulic, 230 to 240 mechanical: Fair idle, good low and midrange torque and horsepower. Good in cars 2,500 pounds and heavier with small engines, or in cars up to 4,000 pounds with medium-sized engines (larger-displacement small-blocks). Good with low-cfm carb and aftermarket manifold, headers, and recurved ignition. Near-stock converter stall speed recommended. Don’t use with more than 10.25:1 compression. Moderately lower gearing OK.
    230 to 245 degrees hydraulic, 240 to 255 degrees mechanical and roller: Rough idle, good mid- to high-rpm torque and horsepower. Good in cars up to 4,000 pounds with large (huge small-blocks, normal big-blocks) engines. Must have higher-than-stock-cfm carb. Intake, headers, and ignition should be matched to rpm range. Can port heads. High-rpm stall-speed converter and up to 4.5:1 gearing preferred.
    240 to 255 degrees hydraulic, 250 to 265 mechanical and roller: Rough idle, mid- to high-rpm torque and horsepower. Cars up to 4,000 pounds with medium to large engines (big small-blocks and all big-blocks). High-cfm carburetion (can use multiple carbs) on a single-plane or tunnel-ram–type manifold with large tube headers, low-restriction exhaust, and hot ignition. Ported heads work best. Very high stall-speed converters and roughly 4.5:1 gearing or higher needed.
  24. henryj1951
    henryj1951
    from USA
  25. I would have to dig a not book out to fill that out. But I will next time I am online. May be fun.
    Actually you should start a thread with that as a game to play and see how many are brave enough to do it. Some may even build a dream engine. Could be fun. ;)
    henryj1951 likes this.
  26. henryj1951
    henryj1951
    from USA
    Might be , i'd be banned like FG
  27. Not likely. Just remember to add the rule no drama and remind everyone that you have a report ****on and you are not afraid to use it. The boss is a go fast junky. ;)
    Besides you could always blame it on me, he's used to me doing bad things. :D
  28. Chris
    Chris
    That is a good read. The duration on the 300 HP cam is 195/202... so would fall into the first category if based on intake duration.
    I have a Weiand WC4D 4x2 intake with 4 97's (600 CFM), 265 log manifolds and a Mallory ignition. Heads are 539 power pack (or FI or 4V...lots of conflicting info there but all in all looks like a decent head to run). Car is light (South of 4,000 lbs even for a curvy girl) and will have 3.78 or 3.54 gears.
  29. If the car is light I believe that you will be happiest with the 3.5 gears. The 3.7 gears are more than doable but they will keep you above your sweet spot on the highway unless you are running an OD.
  30. Roothawg
    Roothawg
    You'll forget about that flathead after you drive this 283!
    hotrodharry2 and tb33anda3rd like this.
