Beed Blasting
Discussion in 'The Hokey Ass Message Board' started by Nick32vic, Nov 19, 2003.
  1. Nick32vic
    Nick32vic
    Is beed blasting only for paint or can i blast the rust off some brake drums i have? We have a beed blaster at school and i was gonna do it in there. Thanks
    Nick
  2. Tim
    Tim
    from KCMO
    im preety sure you could blast them, i dont know why not. but if there abd enuff to need blasted you might want to just buy new ones
    tim
  3. InPrimer
    InPrimer
    I would "mike" the id to be sure they are serviceable before blasting something that is useless
  4. Nick32vic
    Nick32vic
    what would make them useless? We had them turned and need to clean the rust off of them.
  5. Kojack
    Kojack
    I think he ment if you spend the time to bead blast them, then mic'ed them to see if they could be turned.
    I blasted mine to get all the light rust off the top of them before painting that. I don't think you'll have a problem at all.
  6. Nick32vic
    Nick32vic
    Ya ya! That why i need to blast them, so we can paint them. I already had them turned. I just need to get the rust off the top. what does "mic'ed" mean? I have 2 hours of Auto Mechanics class to waste so if i waste the time it dont matter anyways.
  7. Kojack
    Kojack
    I think I spelled it wrong. Miked, or mic them... I don't have a clue how it's spelled. It's just when they use a tool to measure the thickness of the drum in milimeters(I think) to see if it can be turned.
  8. Elrod
    Elrod
    It's short for micrometer.
    A micrometer (my-krom-uh-ter) is an instrument for measuring very small distances.
    So, you should have them mic'd to see how much metal has been removed.
  9. drLovely
    drLovely
    mic, short for micrometer i believe.
    I blasted all kinds of stuff, cleans it right up.
  10. Unkl Ian
    Unkl Ian
    [ QUOTE ]
    [/ QUOTE ]
    You meansure the inside diameter of the drum to see if it is under the maximum specification.
    You measure the thickness of brake rotors to see if they are over the minimum spec.
    The maximum inside diameter is frequently cast into the drum.
    Anyone who has a machine,should have the proper tool for measuring drums.
  11. badpat
    badpat
    [ QUOTE ]
    [/ QUOTE ]
    "waste"????????
  12. A good rule to follow is clean the grease off the part or use a wire brush first if it is just scaly. This way you won't contaminate the bead blaster with chunks of rust and grease. The chunks plug the gun and the grease makes a mess.
  13. Nick32vic
    Nick32vic
    badpat,
    yes waste, the teacher is a joke, he doesnt teach us anything, he just tells us to work on our car and doesnt check to see if we didnt right. Probably because he wouldnt know right from wrong. He grades us on how long we worked basiclly. Once i adjusted my brakes and checked all my pads/shoes and some other kid put wiper blades on or somethin and got a better grade for that day cus it took him longer. LIke I said, the TEACHers a joke and doesnt TEACH
    fordnutz,
    we got all the grease off already.
    Nick
  14. badpat
    badpat
    that's really sad, especially if you are into rods... i hope the wiper blades look good.
  15. quickrod
    quickrod
    waste and auto mechanics should never be used in the same sentence again nick are you crazy?and yes, you can just about glass bead{not beed}anything rusty,but your teacher probably could have told you that....pay attention [​IMG]
  16. Nick32vic
    Nick32vic
    NO quickrod you dont understand, the teacher is an idiot. He has about the same IQ as a mouse. He doesnt teach us anything. I do pay attention too. But i cant learn if he doesnt do anything. I can learn most of what i need to know from my dad anyways and if he doesnt know i ask guys in our car club or here on the good ol HAMB. Thank you for everyones input too.
    Nick
